timing belt area squeaking | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Sep 10, 2013.
  1. 24000rpm
    24000rpm F1 Rookie
    2003 360 modena.
    After I replaced the timing belts and their tensioners(hill engineering ones) about 500 miles ago, the car's developed a squeaky noise. Note that it only squeaks when the car is warm.
    Originally I thought it was the accessory belt, so I pull it off and start the car. Same noise. Opened the inspection panel and opened the timing belt protection case, the noise is there!
    I sprayed some water to the tensioner/belt contact area, the squeaking stopped! It would come back after a while.
    This happened to both sides of the timing belts.
    what would be the issue? does anyone have experience on this?
  2. North East Auto Doctors
    65
    conn
    Adam Varney
    Let me guess you didn't use the tool for setting tension.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,944
    The Cold North
    Tom
    ^this^--How did you set the tension on the belts?
  4. 24000rpm
    24000rpm F1 Rookie
    if you mean Clavis, yes, i did use it and set it to factory frequency
    are you saying I made it too tight?
  5. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    If the tension of all belts was set right, you wouldn't be getting a squeek, unless you had a noisy bearing somewhere, which you surely would have found during fitment?
  6. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    You did release the pins that prevent the tensioners (and I do mean the tensioners and not the pulleys) from pushing out while you changed the belts?
  7. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    I bloody well hope so! :eek:
  8. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Never overlook the obvious! :)
  9. 24000rpm
    24000rpm F1 Rookie
    alright guys.
    update: i got the new "diapaz" to test my frequency again, result: 75 hz on the left and 100 hz on the right. phew.....
    I had a local non-ferrari mechanic told me it is the hydrolic tensioner went bad.
    What do you think? after changing timing belt , suddenly the tensioner went bad, both sides?
  10. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Did you put pins in the Hydraulic tensioners when you did the work?
  11. 24000rpm
    24000rpm F1 Rookie
    when I was replacing the timing belt, after the work was done, I put the pin into the hole, and it slided in and out freely (after waiting for the hydraulic tensioner to self adjust)
    after 1 month(now), when I was checking what's going on with the squeaking:
    on one side , the pin can still slide in, but with some friction , on the other side, i can't really insert the pin into it.
    any ideas? is it really the hydraulic tensioner?
