Timing Belt Dilemma Vise Grip fell off | FerrariChat
Discussion in '360/430' started by toussi1, Aug 7, 2020.
  1. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    I have an issue, I was doing my timing belts on a 360
    - My vise grip holding the Cam Gears on the left bank fell off without belt on! (Right side not touched yet)
    - The cam gears moved position, the yellow marks are still on them, so I know they have to meet, but it is impossible to turn the cam gears by hand.
    What tool would you use on both to move them so the yellow mark meets so I can put the belt back on?
    Any help appreciated, STUCK! attached photo for reference of the gears
  2. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
  3. imahorse
    imahorse F1 Rookie
    4,276
    WI
    Dustin
    Oof. Ive always been terrified of this happening. Perhaps if you could wedge something in between the bolts on the cam gear that you would able to get leverage on and rotate.
    Sent from my SM-N950U using Tapatalk
  4. fatbillybob
    Aug 10, 2002
    28,646
    socal
    That's a poor inaccurate way to serivce the belts
    f355spider and Skidkid like this.
  5. brogenville
    brogenville Formula 3
    2,220
    Robin
    Not disagreeing, but it’s what Ferrari recommend! [emoji16]
    brookliner7 likes this.
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,384
    Santa Clarita, CA
    Use a large pair of Channel Locks and use the old belt as a buffer, so you don’t mess up the cam gears.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    How about the rubber band wrench
    Sent from my moto g(7) using Tapatalk
  8. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    "You are not alone".
    It happened to me last year on my 1st timing belt job on the 360... I think I've written a post about it back then... The intake pulley slipped a few tooth and was impossible to turn back "by hand". I slept (poorly) over it and the next day, came up with a solution.
    I used the old belt on the intake pulley and the crank pulley, using the wrench on the crank to turn the engine over and that was enough leverage to make it turn... Once back in place, use vice grip to hold it again.
    Then turn back your crank pulley to its original marks. It worked for me...
    Good luck...
    imahorse likes this.
  9. Skidkid
    Skidkid F1 Veteran
    9,497
    Campbell, CA
    John Zornes
    flash32 likes this.
  10. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Thank you for all the tips. Towing it now to the shop would be a diseastor ‍♂️
    Do you think one of these in 16 inches long will work? No visegrips are made that open as much as the pulley.
    I would have to put something around the pulley as I tossed the old belt out.
    If I can put my vise grips on the pulley very so lightly so it grips but slips I can then fine tune the top and bottom pulley ??
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,701
    Central NJ
    Dominick
    I was referring to this ..not a good idea ?[​IMG]
  12. fatbillybob
    Aug 10, 2002
    28,646
    socal
    IF you are going to ghetto this please read post #6 and think about what this poster has written. Then put an old piece of belt to a pulley, grab the belt close to a pulley circumference and use the resulting leverage and see if you can convert the mental image into physical action. It is easy to show hard to describe.
  13. fotostars
    Feb 6, 2015
    345
    Bay Area
    Read my post above. This wasn’t a big deal to rotate using the crank pulley and the old belt. I would not recommend trying to grab the pulley you’re trying to bring back with anything other than the old belt.
  14. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Take the plate off the rear of the head and turn the cams with a 21mm spanner. Simples.
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    It's not the easiest place to get access and leverage but this is how you adjust the cam timing if needed.
  16. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Pardon my ignorance, but is this the area? Inside the engine under those plate covers? This is 21mm?
  17. yelcab
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    Correct. The wrench that fits there is 21mm.
  18. one4torque
    one4torque F1 Veteran
    5,602
    Houston
    One4torque
    I wish Aldous voice would emigrate to the colonies here..... Texas is nice chaps! We would line up our f cars around the block for your wizardry!
  19. fotostars
    Feb 6, 2015
    345
    Bay Area
    @toussi1 , eager to hear if and how you managed to recover your cams timing?
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    You might want to think about a pair of triangular wooden blocks with a through bolt or stud next time, the mole grip idea looks a bit dodgy. I have not worked on the 360 belts.
    mwstewart likes this.
  21. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Will be working on it next week. I will be taking a video and I can post it here for the next guy who ends up in this mess.
    If all fails, will have to tow it to a shop, I did take video and photos of the gears and belt before I un-did the tensioner, so I'll have something to compare with.
    For anyone who has never done this type of work before, I suggest you just pay the $900 labor and have someone do it, a 7 hour job now is turning into a 30 hour job haha
    John_K_348 likes this.
  22. yelcab
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    I find that a 21mm open ended wrench has trouble turning the cam shaft because of the access to the cam shaft interferes with the fixed angle of the open ended wrench. The next time I am in this spot, I would buy a 1/2 inch, 6 pointed 21mm socket, and grind away some of the material inside the socket to fit over the round section of the cam shafts. Then I can use a 1/2 rachet to turn the cam shaft.
    If you can measure the diameter across the round part of the cam shaft ends, it would help the effort.
  23. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,372
    Honolulu
    Kevin
    A crowsfoot socket might be a good choice.
    I am sure there is a nice tool that can lock in those gears. After reading this thread I will definitely purchase or fabricate prior to my next belt change.
    A video would be great to see. I just did the major belt service on my car and this is probably good advice for a lot of people. I probably had ~20 hours into mine but then I was working slow and trying to enjoy the process and using a lot of my tools! I have good environmental controls in my garage so often it is the nicest place to be so no rush! LOL
    John_K_348 and imahorse like this.
  24. yelcab
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    No it's not. It is too big to fit inside the head cavity where the cam shaft lives. I tried. And the flat parts of the cam shafts are kind of shallow which make the crow foot engagement unstable and very hard to use when you add the extension on top of the crow foot.
    Kevin Rev'n likes this.
  25. Kevin Rev'n
    Nov 29, 2009
    24,372
    Honolulu
    Kevin
    Ahh, Could a grinder remove the material to make one work? Maybe a fancy flare nut socket?
