Timing Belt Failure After Only 150mi!! WTF!?!? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Adaptel, Apr 16, 2008.
  1. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,510
    Dumpster Fire #31
    SMG
    oohh man, sorry to hear and see. this is exactly why I updated the design and the belt. a couple points, belts are age related, from the pics it looks like a construction failure. the belts are made in a spiral wound process, and that seems to be how it separated out. they most likely are older belts too, sitting on a shelf. another point is how the belts are shipped, I've received belts that have been folded way to small and rejected them, if the radius of the bend is smaller than 2" dia then it will break the internal cords and set you up for that type of failure. all my info comes from the engineers at Gates and Continental.
    here's a link to the new pulleys if you haven't seen it http://www.ferrarichat.com/forum/showthread.php?t=91286&highlight=adjustable+cam&page=5
  2. Steve Magnusson
    26,998
    I believe that you have that backwards. It's the 70's 308 have no inside flat covers and they were added in the 80's -- see:
    http://www.eurospares.co.uk/partTable.asp?M=1&Mo=662&A=1&B=38780&S=
    (although this illustration is for the euro version 308QV, the US version 308QV SPC also shows them on TAV 8 -- I'm unsure if they were used on the 308i-2V or not)
    The tricky bit is that the flat covers need to be put in place before installing the timing belts. Often the Assembler forgets this step and only realizes the mistake after he/she has got the timing belts on so doesn't go back to correct the error and leaves the flat covers off. You should consider putting the flat covers back on during your repair IMO.
  3. Adaptel
    Adaptel Karting
    Jul 21, 2007
    89
    Concord, NH USA
    Kevin Pearson
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,510
    Dumpster Fire #31
    SMG
    hahahah, oh man that was me yesterday on a 3.2, totally flip'n forgot the covers. it all had to come off again to put it on, cam pullies too! that's what happens when you're working late. lost about 45min on that one. oh well, it's done right now. oh and yes the cam covers were on too, had to undo the cams and everything! uggh
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,510
    Dumpster Fire #31
    SMG
    too tell if you should have a backside cover, look at the back of the belt cover and see if you have M3 threaded holes, if not no cover, if so then you have a cover.
    looking at your pisc again, you have bosses on the cover with the threaded holes, your covers seem to be missing.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Don't know if it's the same on 308's but Euro 328's do not come with the back covers although the front covers have the threaded holes.
  7. Steve Magnusson
    26,998
    I should've looked at more than the picture -- the US & euro 308QV SPC says the flat covers were used only up to engine SN 2187 (although I can imaging why they would drop them).
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Adaptel,
    I can feel your pain....
    Your post will cause me sleepless nights until 83958 is back on the road **and** with more than 150 miles!
    Can anybody decipher the belt numbers into a 'batch'? If so, would the 'batch' number be similar for the TR series?
    I hope to compare the TR belts that I put on my car to determine if they are from the same batch. The engine is still out, so I still have time to change them if needed.
    Man-o-man, I feel your pain. The bright side..... at least we derrive pleasure from 'working on them' as well. It could be worse, you could be in a legal battle with a shop AND Dayco while you also dump a huge additional amount of $ into another shop to re-do the work.
    Best wishes...
    Rgds,
    Vince
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    and I thought I'd never be able to sell the pair I have on the shelf :)
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    It might be worthwhile to chat with some folks like this:
    http://www.rapid-response-consulting.com/article050707a.html
    google under:
    "failure analysis" consultant belt
    it may help you to get the attention of the dayco folks (best case) or it may help you determine the root cause and not repeat it once again during the repair.
    Good luck,
    Vince
  11. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    did you check for a siezed cam? perhaps due to silicon in an oil galley(?)
    Rgds,
    Vince
  12. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    I am so sorry to hear about this. It was an OEM belt no?
  13. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Or cam bearing caps mixed up......
    Jay
  14. duskybird
    duskybird F1 World Champ
    12,723
    29 Electoral Votes
    Bill B.
    Did you put a straight edge across the cogs?
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Kevin and I discussed this, as we're friends and neighbors...
    Back in 1983, I purchased a brand new Euro 308QV GTB...and at 1,200 miles, whilst pulling into a driveway (engine speed just over idle), the front-most timing belt broke. The sames sounds and belt appearance as Kevin's car. As the car was a "Euro", there was no warranty. A big ouch!
    Long story short, I recall a conversation with someone (vendor or perhaps a Ferrari dealer) later on that there were "issues" with the "white-lettered" belts and the new replacements had "yellow" lettering and/or a different part numer. I recall, although this was nearly 25 years ago, that there was even a TSB on this subject. My feelings, based on changing 100's of belts on these cars, is that this is simply (albeit, an expensive result of) a defective belt, perhaps even a NOS one.
    Although I find the theory of "no inner covers" interesting, I know for certain that my BB never had them, nor have I ever had an issue with debris destroying a belt. I would say that less than 50% of the 308/328 variety of cars that I've changed belts on don't have inner covers...and I suspect, many did not even have them initially equpped from the factory.
    I'd be on the phone with RT and FNA demanding restitution, if it were my car.
    Onward,
    David
  16. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Yes, it is quite the achilles heel. You would only need one small hard thingy to fall into one of four places on each belt....so you easily have 8 points where a belt is aggressively meeting either a toothed wheel or a bearing. At that point comes the big squeeze..its just like any feed chute, and the belt would most likely be cut instantly or at least a hole punched through.
    Check each toothed wheel surface and bearing surface 360 degrees and look for a mark. If something got in there, it probably left one.
    My 2 cents.
    -Rjay
  17. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Whoa Nellie...!!! All you folks out there calling for blood lust from RTGT and Dayco need to slow down a bit...
    While I could not be more sympathetic for Kevin. The fact is you really don't (and likely can never) know, with complete certainty, what happened with these belts. These parts have been through a lot of hands on their way to their final destination. And, anyone along the way could have damaged them... there are many possibilities...
    1) Were they defective from Dayco?
    2) Were they aged NOS (and past their "use by date") from RTGT?
    3) How many people have touched them and may have mishandled / mistreated them?
    4) If they were shipped, did the UPS guy step on the box in the back of his truck?
    5) While they were being installed, did something accidentally damage them?
    6) Has any contaminant been spilled on them at any point?
    It's more complicated than simply pointing the finger at someone.
    What you can do is call Dayco, and find out if these belts came from any lots previously identified as "suspect" --- Do it casually. Say that you have had these belts for a while, and you're wondering whether or not to use them or get fresh ones --- don't let them know you've already installed them and had a failure.
    Also, place a polite call to RTGT, and calmly tell them what happened. These guys have been around a long time, and they have an outstanding reputation for customer service and satisfied customers. I can guarantee that if you don't accuse them of "screwing you over" right off the bat, they will do everything they can to assist you and to try to make you happy.
    Regards,
  18. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Please add more clarity.... am unsure of the implication.
    Rgds,
    Vince
  19. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    I once blew a brand new belt back in college, thankfully on a non-interference engine, and it turned out the belt was 10+ years old and dry-rotted! I would call Dayco and without giving them too much info, just see if there is a way to date the belts ie. just like you can on tires....there is usually a secret code somewhere.
  20. duskybird
    12,723
    29 Electoral Votes
    Bill B.
    During assembly did you put a straight edge across the cogs to see if they were aligned? I've busted blower belts due to not having perfectly aligned cogs.
  21. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    In honesty, this is why I am not an advocate of changing out the belt(s) and associated parts every 3 years. It's extreme overkill and every time you do it, you run the risk of replacing perfectly good parts with faulty ones. And the more often you do it, the better your chances of this happening.
    My grand dad always said "NEVER, NEVER tear into a perfectly good running engine."
  22. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    While that's true, they did add a couple of things starting with engine s/n 2188, TAV8 #45,46,48, & 49. I own an '85 Euro with these on it. 45 & 46 are pointers to the cam gear flange timing marks, in lieu of the almost impossible to see metal arrows on the rear belt covers that were eliminated. The other two parts are described as:
    48 - Protection plate for right belt.
    49 - Protection plate for left belt.
    I've never seen an SB for this change & I have a pretty complete set. Just missing the 87-88 SBs (assuming they were ever printed).
    BTW, See SB 10-9 Toothed Timing Belts - P.N. 111334 w/White markings 9/26/84
    Starting from 4V chassis #47221/Engine # 336 engines are equipped with a belt made with 'higer temperature resistant compound' . The new belt has white markings and the same part # as the older belt with green markings.
    A similar white marking belt is introduced for the 2V engines.
  23. Adaptel
    Adaptel Karting
    Jul 21, 2007
    89
    Concord, NH USA
    Kevin Pearson
    #48 Adaptel, Apr 17, 2008
    Thanks everyone for the suggestions & info. I am going to follow up through the appropriate channels to get a definitive answer on this. I stare at the break point & can't come to any compelling conclusion as to the cause. I think only a forensic analysis could conliude anything useful.
  24. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    What a horrible thing to happen! Looking at that belt it would appear that rubbing or a foreign object was the cause. If a cam had siezed it would have ripped the teeth straight off the belt and no more. However,while the engine's beeing stripped, a thorough check of the oil gallerys to the cam caps should be carried out, just in case any machining debris has caused oil starvation. Good luck with your repair, i hope you get to enjoy your car again soon.
  25. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,269
    Indiana/North Carolina
    JIM
    My sympathies go out to you. This has got to be gut-wrenching! I hope the internal damage is minimal.
    JIM
