timing belt pad | FerrariChat
timing belt pad
Discussion in '348/355' started by fatbillybob, Apr 17, 2007.
  1. fatbillybob
    Aug 10, 2002
    29,151
    socal
    #1 fatbillybob, Apr 17, 2007
    Does anyone have a spec for the distance of this timing belt pad to the timing belt? When the timing case is tightened these pads lock into place so you can control the clearance of the pad to the belt. How are others of you setting this clearance?
    Ferrari lists no spec unless it is in a TSB.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I think in the earlier thread we decided that since there is apparently no factory spec for this, it should be installed with 1-2mm clearance. It's obviously a BAD idea to install it with no clearance, it chews up the backside of the belt and wears the finish off the shoe. If someone can come with a factory recommendation, GREAT!
  3. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    I set mine to 1mm. When I 1st removed the top section of the cam cover on the LH bank, the pad was installed backwards. :) When I swapped it around, I slid a 1mm feeler gauge in there and set the "gap". :):)
    Have not checked it since, but I assume there are no issues. :)
  4. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    Somewhere between a matchbook cover and a thumbnail! :D
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    ....tolerance to within an RCH ;) !!!
  6. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    Yes, using-of course-the appropriate Ferrari adjusting tool-the BFH
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    LOL :p!!!! Also the precision alternate to the BFH....... the BAFH!! ;)
  8. Llenroc
    Llenroc F1 Veteran
    5,526
    Colorado
    Vern
    For whatever its worth FBB I used to set mine at 2mm, enough to keep the belt down, if in fact it would ever move off of the sprocket, but not to low as to rub on belt pad. When I looked at the belt and the way the system works I couldn't see how or why they are even there. I actually painted the bottom of mine to see if they ever touched the belt. On the next belt service paint was not touched, so as I said before I'm not sure why they are there?
  9. fatbillybob
    Aug 10, 2002
    29,151
    socal
    Well I guess we are all doing the same thing still. I'm with Vern..there is no touching of pads to T-belt and I really don't know what these are for. If a belt was going to jump teeth I doubt that these pads would stop it. If I take them off my race car I can save 2 ounces!
  10. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Hey PAP, you made my day! When I did my major I found the pads installed backwards. Thought I was the only 1! Set mine with virtually no gap. Will pull the covers to see if they are "shredding" my belt.
  11. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    What document shows the orientation??? Maybe they are NOT backwards :eek: !
  12. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Funny that. :) I only had the LH bank installed backwards. Well, it could have been both now, I forget. :D It is in the correct way now, with 1mm gap. Set them both to 1mm. :)
  13. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    #13 Jagbuff, Apr 18, 2007
  14. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Was the cam guide in backwards there mate?
  15. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    You are right - I didn't install it though :)
  16. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Gothspeed, if I recall correctly there is a detailed diagram of the front view of a 348 motor in the technical book and possibly the workshop manual. Details the belt/ pulley system etc. I remember scratching my head looking at the diagram and my partially disassembled motor thinking something just isn't as it should be here! The shreds of rubber in the belt housings also hinted at a problem!
  17. PAP 348
    Dec 10, 2005
    100,224
    Pap
    There was another thread here somewhere, discussing this. :) There IS a correct way to fit them. :):) Mine were installed backwards. All ok now. :):)
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Just wanted to make sure so when I get my 348, I will know how these go :eek: :eek: !!!!
  19. PAP 348
    Dec 10, 2005
    100,224
    Pap
    IF...............you get a 348! :p:p:p
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    IF???:mad:
    When!!!! :D :D :cool: :D :D
  21. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Yeah yeah yeah!! :cool::cool::cool:
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: :D :D :D When!!! (Again!!!) :cool: :D :D
