Timing Belt Question | FerrariChat
Discussion in 'Technical Q&A' started by alex360S, Apr 8, 2013.
  1. alex360S
    alex360S Formula Junior
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Is it normal for the long stretch side of the cambelt ,opposite the tensioner, to vibrate? It's not slapping around, just vibrating in and out by about 1/16"-1/8". The tension adjustment is correct at +/- 200hz, just never noticed it. Want to be sure before closing the hatch and enjoying the season.
  2. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    I do not have the answer to the belt question. My question is where did the info about 200hz come from? Can you please explain how you measure the 200hz?
    Thnaks
    CK
  3. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
  4. tazandjan
    39,266
    #4 tazandjan, Apr 9, 2013
  5. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    If you have a GoPro I'd suggest you shoot a bit of footage at the highest frame-rate you've got and post on-line (effectively in slow-motion). That might assist one of the pro's in helping you.
  6. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Thanks Greg. Will try this evening and post soon after. Good suggestion.
  7. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Here's a link to the video. Maybe it's normal, just want to be sure. IMG_2426 - YouTube
  8. Glassman
    Glassman F1 World Champ
    With the engine not running you can move the belt a little bit with one finger. In fact you can twist the belt to about 45 degrees.How would the belt then not move around a little bit when running?
  9. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #9 finnerty, Apr 11, 2013
    I will let one of the F-tech experts here, who have made direct observations of running 360 t-belts, comment as to whether this is a "normal" amount for that particular system.
    However, I can tell you that it is typical of most any belt-drive system ---- to have some significant movement / deflection of the belt, in between pulley spans, as you are observing there. As the belt exits off the pulley, there is a certain amount of stiction (between the contact surfaces of the belt and of the pulley) suddenly releasing plus belt relaxation (rapidly transitioning from bend / flex to straight) that causes this ---- sets up an oscillating wave in the belt.
  10. FerrariDublin
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    Well done on the video, very clear. Seems to me that from 1:17 is where one gets the best view of the issue that's causing you concern?
    I'm not qualified to advise, but this is the internet ( :) ) so for the time being I'll say, relax, it looks good to me! I'm sure someone will be along shortly to give you the low-down.
    Did you carry out the work yourself and if so are you a mechanic by trade or a DIY'r?
  11. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Yes I carried the work out myself. No I am not a mechanic, but very hands on and try to but upto speed on the technical aspects of this hobby. This is what makes me tick. I love to learn and I love sticking my hands in my own car, especially this one. I completed a major last spring but noticed a coolant leak from the heat exchanger as I was doing my yearly maintenance this year, so I removed the exchanger and inspected it together with a pressure test to make sure there were no internal leaks. Put it all back and did fluid change with no leaks anywhere. Noticed the belt deviation as I was inspecting for leaks.
  12. FerrariDublin
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    Well done yourself! Planning and patience can get you a long way on these cars. Looks all very nicely buttoned up and tight.
  13. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Everything torqued as per specs and marked down and all documented. All belts are tensioned and verified, all are within specs too. Thanks!
  14. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    Looks normal to me.
    The load on the belt is not constant, it varies as the valves are opened and closed. Of you plot the load on the belt it would look like a series of sinusoidal curves, the peak load being when the valves are opened. The fluctuation in load is what causes the belt to "vibrate".
    Also , the belts are not under the same load at the same time, this is why Ferrari specify a "cumulative" frequency for the belts. Good practice to check the belt tension at various crankshaft positions, what you are looking for is that each belt reaches similar high & low frequency readings that add up to the specificed total at the various crank positions.
    M
  15. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    So what's the consensus, close her up, stop panicking and enjoy the season?
  16. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Yes.
    Cool video, though. Mechanics at work.
