Timing Belt Replacement | FerrariChat
Discussion in '308/328' started by wrouster, Apr 4, 2014.
  1. wrouster
    wrouster Karting
    Feb 22, 2012
    52
    Michigan
    William Rouster
    Anybody know how long you can expect a good mechanic to take to replace timing belts and rollers on a 328? The tutorial makes it look like a 6-8 hour job, at most. A mechanic I just talked to said 10-12. Thanks!
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,285
    Illinois
    #2 JohnnyS, Apr 4, 2014
    I would tend to believe the 10-12 hr process. Having done mine, there are a lot of little nuts to take off and lots of contortions to do to get at them. All needed to be done in reverse to put it all back together. Maybe 6-8 hrs if noting else is done like the water pump.
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,360
    Last time I had mine done by an Indi here I dropped it off at about 8:45 a.m and it was ready by 1:30pm - but all he did was change the timing belts & put new V belts on it. My car is a UK 328 with AC on it. I would imagine you could add another 30 minutes if you wanted new tensioner bearings stuck on it.
    If all you are changing is the belts, its not a 10 hour job assuming you don't hit any snags / seized nuts or bolts etc.
  4. mwr4440
    58,157
    Bavaria, The 'Other' Germany
    Mark W.R.
    If you want a data point, look at the time maintenance schedule manual. It will tell you what Ferrari will bill hour-wise for the belts and tensioner bearings replacement ONLY.
    BUT, these are old cars. If you don't find some "While you are there" additional projects, you probably did not look hard enough. A good knowledgeable wrench would do the same and the time required would go up.
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    That seems perfectly reasonable. But I am getting the impression that its a lot longer on US cars. I have seen "lots of little nuts to take off" mentioned here and on other threads. We dont have these on our cars, are these something to do with the fact the cam belt covers have backplates on US cars? Also our A/C compressors are easier to get out of the way I think, than the US York units which seem to be bigger.
  6. JohnnyS
    Oct 19, 2006
    15,285
    Illinois
    Yes on the back plates for the cam covers. Those little nuts are difficult to get at especially 3 of them.
  7. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
  8. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    +1
    Not seen as a big deal in the UK but in the States it always seems to be at least twice the price.
  9. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,199
    Atlanta
    Tom Spiro
    My experience is that its a 5-10 hour job. if done right it takes longer... water pump rebuild etc.. but i guess if you are great at wrenching - 4-6 hours can happen just for belts... but that is like Ron Reineke expertise.... having done it hundreds of times ..... for me its like 2 full days at best. getting the AC compressor out of the way is its own nightmare!
  10. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    On my UK 328 it took me two lots of 4 hr blocks..
    I started at 4pm and have everything off by 8pm..
    I had to pick up the AC belt and AC idler pulley bearing as I had everything else besides them so the next day after work it took me another 4 hrs to put it all back together,,that's just all belts and tensioner bearings as well as replacing the AC idler pulley bearing and including refilling and bleeding the coolant.
    Biggest time waster is removing and refitting the AC compressor..that's almost a 2hr job on its own!!
  11. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    Friends,
    It takes me 2 months!
