Timing belt rock guard | FerrariChat
Discussion in '308/328' started by mixedgas, Aug 28, 2023.
  1. mixedgas
    mixedgas Formula Junior
    276
    Ramona, CA
    Good morning, I'm taking my 85 QV apart for maintenance and I noticed this car is missing the "rock guards" that go behind the timing cover (i.e. between the timing cover and head). I believe these are Ferrari part numbers 117628 and 117627, and are seen in the attached image from a current BaT listing for a different car.
    My question is if these are actually missing from my car (should my car have these?) and if yes, are they important to have? I've seen a few 308 engines that are missing them, so perhaps they are not important.
    Thanks!
  2. Steve Magnusson
    26,880
    Not super-critical (as the carb cars don't have them -- can't recall when they were introduced). What probably happened is that the Mechanic forgot to put them on before doing the timing belt replacement, and didn't want to redo things, after realizing his/her mistake, so just left them off. Do your Aluminum cam covers have the corresponding female threaded holes tapped? If so, yeah, you should probably have them. (My foggy recollection is that maybe some euro version cam covers have the corresponding bosses on the cam covers, but are not drilled/tapped -- i.e., the backside covers showed up on the US version cars first.)
    mixedgas likes this.
  3. cstorry
    cstorry Karting
    Apr 28, 2005
    91
    Ottawa, Ontario
    Chuck Storry
    My 85 308 euro does not have them either. Is your car a euro model?
    If you look at the parts book for the euro QV (i.e. not USA) I believe it says that those guards are not used after a certain car (from engine 2188).
    I note that the 328 has similar euro vs USA no guard vs guard. Instead of the guards there appears to be TDC pointers and a different set of belt guards.
    Chart 008 - timing system - controls
    I wonder why?
    mixedgas and ferrariowner like this.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Yes QV should have those guard and Steve is right the previous mechanic probably didn’t put it back but the only way to remove those guard is to either remove the cam pullies or remove the cam shafts from the cylinder heads.
  5. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    My euro qv did not come with the rock guards. Just the TDC pointers.
    mixedgas and cstorry like this.
  6. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    My late-84 Euro QV did not have with those rock guards either when I bought it 10 years ago (I have the TDC pointers as mentioned by Ron). When I wondered about this here, I recall the consensus was as Chuck mentioned, most Euro QVs didn't have them from the factory.
    Gordon
    mixedgas, cstorry and ferrariowner like this.
  7. mixedgas
    276
    Ramona, CA
    Quick note here that my 85 is a euro GTS and has engine number 2951 installed (I presume stock, no indication the engine has been changed). My timing belt covers have threaded holes where the rock guards could be installed. I think I'll keep an eye out for a reasonably priced pair of guards (seems like a good idea to have them) but wont obsess about having them. Thanks all!
    350HPMondial likes this.
  8. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,355
    Dumpster Fire #31
    SMG
    Euro engines use a different style of belt 'guard' there's a sheet metal'fence' that sits by the lower drives to keep large debris away.
    Honestly unless you're out WRC in the dirt and gravel I'm not sure that one's risk is high enough to warrant the switch.
    Also note, the fiberglass back panels are a right PITA to install and make service intervals that more complex. The camshafts can not be removed without also taking out that back panel together..i.e. to pull the panel or the cams require removal of them together as a unit (both cams and panel). The tensioner assy also needs to be removed first. And we haven't touched on the little m4 screws that hold it together.. Little buggers are not fun.
    308's don't seem to have an issue with no dust cover. Given that's it's mostly a USA thing, I wonder if it's there more due to a regulation then actual design improvement.
    cstorry and Thomas Magnum like this.
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,355
    Dumpster Fire #31
    SMG
    Just removing the pulleys won't work unfortunately, the cams must come out.
    miketuason likes this.
  10. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    560
    NYC
    Joe
    cstorry and GordonC like this.
  11. Rifledriver
    37,134
    Those were origionally installed at the request of the head of Servizio Asistenza Technica at Ferrari North America. A man named Ken McKay. It was USA only at the beginning. He received so many complaints for a while they quit installing them because so many complaints came from experiences of them trapping debris that caused more belt failures than not having them. It was later decided to install them and a decision was made to do it on all cars. On 355 they got smart and quit using them.
    GordonC, miketuason and smg2 like this.
  12. Brooklands
    Brooklands Karting
    Aug 4, 2014
    113
    North Vancouver, BC
    Phil Delory
    My 83 QV guards had holes just big enough to slide over the cam pulleys before I pulled the cams. Does that mean somebody opened up the hole in the fiberglass a tad?
  13. Rifledriver
    37,134
    .It means they opened them up a lot. By the time the holes are that big little need for the guards....if there ever was one.
