timing belt shelf life | FerrariChat
Discussion in 'Technical Q&A' started by blainewest, Dec 25, 2005.
  1. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    I just bought a set of t-belts for my 308 gt4 and they are actual pirrelli isoran belts with the numbers 101 R 254 and 107833 stamped on the belt. They are clearly new but I have no idea how long these belts have been sitting on the shelf. It seems to me I read somewhere that pirrelli hasn't made these belts in years which would mean that mine are not fresh. Is this something I should be worried about? Do these belts have a "shelf life"?
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Yes, they are actually Dayco/Isoran now. So they are older.
  3. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    The Dayco's have both the model number and batch numbers on them, 096s254 and 94485 being the part numbers (in blue) and batch numbers i.e. (in white) printed on them, the batch number is sequential every 5mm or so on the belt so they tend to have 5 numbers printed in a Colum on each belt, in the case of the one I've got in front of me 05053119,05053120,05053121,05053122, 05053123. with the first 6 numbers indicating year(05) month (05/may)and date (31st) of manufacture
    Personally I wouldn’t fit something older than a year or so on a car, after all we change the belts to ensure there are new ones on.....why replace an old belt with another old one, when Daniel at Ricambi can supply new ones for only a few dollars
  4. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    who did you buy them from ?
  5. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I'd bet you can't get belts that were made less than a year ago.
    Dave
    Herman Ronald likes this.
  6. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    Dave the 31st of May 2005 is 7 months ago...............always pays to read before you type ;)
  7. Ricambi America
    Sponsor Owner
    #7 Ricambi America, Dec 26, 2005
  8. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    #8 andrewg, Dec 26, 2005
  9. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Okay, possible dumb question, but how do we know '05 refers to 2005? Does it actually have to mean that, or could it also mean '95? I would really feel good knowing when I put on new belts that they are really that new. This is one of the best posts in a while. Now I have to go look at the belts I bought and check the dates.
    Lastly, is there any better made belt on the market, something more robust, or more indestructable? Kevlar, anything? Heck, I wouldnt even flinch paying over $100 per belt if I knew they were almost bulletproof for the same maintainance period. Also, is there any other cog pulleys on the market that can use a upgraded belt design? Better and larger idler bearing?
  10. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
  11. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Okay, I just went and drug out some of my new parts. My belts are 107833, Ferrari belts, Dayco Isoran 101 R 254, all letters in white. Also, in another area of the belts, white numbers 4132037, 38, 39, 40, 41, on one, and 4132093, 94, 95, 96, 97, on the other. If '05 on the other belts is the year, what the heck is '41? If '05 is May, what month is '32?
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #12 No Doubt, Dec 26, 2005
    Hill Engineering/Ricambi carries better tensioners.
    John DiGiacoma at East Coast Jaguar builds (re-builds) superior 348 water pumps...at a fraction (typically a mere $199) of the cost of OEM (often more than $800). These water pumps have twice the Ferrari warranty and they lower parasitic drag by using better bearings. He also uses better seals. Call him at (302) 475-7200 or 1-800-475-9257. An old example of his work is here: http://cgi.ebay.com/ebaymotors/ORIGINAL-FERRARI-348-WATER-PUMP-2YR-WARRANTY-NO-RESERVE_W0QQcmdZViewItemQQcategoryZ42606QQitemZ4599528001QQrdZ1QQsspagenameZWDVW
    This company makes some interesting silicone and EPDM, Hypalon®, urethane, Mylar, Kapton®, Melinex®, neoprene, fiberglass, polyester, Kevlar® and steel reinforcement custom belts: http://www.beltcorp.com/products/custom_fabrication/default.asp
    Interestingly enough, for less than $50 Porsche put a timing belt tension sensor on their giant rubber timing belt system for their old 928 (see picture).
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Good point.
    Also, I'll spring for the $200 to buy John's 348 waterpump if you're willing to rig up some sort of side by side or back to back test against an OEM (say, for turning resistance, pressure before leakage, etc.).
  14. blainewest
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    Wow! thanks for all the great replies. I'm in the same situation as krowbar though. Does anyone know what "101 R 254" means? The only other thing stamped on my belts is "D2" on another point on the belt. Anyone? Bueller?...
