Timing belt tensioner bolt question | FerrariChat
Discussion in '308/328' started by mixedgas, Jul 22, 2019.
  1. mixedgas
    mixedgas Formula Junior
    Apr 23, 2019
    293
    Ramona, CA
    Hi there, the big timing belt tensioner bolts on my 328 had some white goo on the threads upon removal. Do you folks put anything on the tensioner bearing bolt like antiseize, or alternatively loctite?
    Thanks!
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I do not. But, I do clean the goo off the threads if I'm reusing the bolt.
  3. mixedgas
    Apr 23, 2019
    293
    Ramona, CA
    Thank you Thorn, I think I'll clean off the white oily residue and use a small amount of torquing compound on the threads. Mostly I was looking to see if anyone uses threadlock on these.
  4. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,531
    Raleigh
    Kevin
    Might be white lithium grease.
    I would recommend cleaning and lubricating the tensioner mechanism itself, when replacing the tensioner bearing.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,004
    Isle of man- uk
    A few drops of loctite nutlock will do no harm and u know it is not going to back off
