Timing belt tensioner mountimg studs | FerrariChat
Discussion in '308/328' started by Ehamilton, Apr 24, 2023.
  1. Ehamilton
    Ehamilton F1 Rookie
    2,661
    Durham, NC; USA
    Eric Hamilton
    What is the thread on the three studs holding the tensioner assembly on an '81 GTSi? M8x1.0 or M8x1.25?
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
  3. Ehamilton
    Ehamilton F1 Rookie
    2,661
    Durham, NC; USA
    Eric Hamilton
    Yep, whatI expected. The nuts I just took off my rear bank tensioner are 8x1.0
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    What? how ?
  5. Steve Magnusson
    26,870
    It's easier to brutally mangle a M8x1.0 nut down a M8x1.25 stud than a M8x1.25 nut down a M8x1.0 stud ;).
  6. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    Well, I shouldn't talk ...
  7. Steve Magnusson
    26,870
    I'm just as shocked as you (and just guessing), and hope that the OP posts some pics of the destruction (but what I posted is true -- M8x1.0 nut on M8x1.25 stud requires much less deformation than the other way around).
  8. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    I once completed an entire repair using a helicoil for a 10mm x 1.5mm hole, only to find out the correct pitch was 10x1.25. I actually have forgotten how we I got it to fit.
  9. Rifledriver
    37,126
    I'll take a helicoil 10:1 over a time cert anyday but for just such screwups they make a 'BIG CERT" Has an overly large OD. Had to put one in a head for an intake manifold stud repair recently. Saved me from some welding and machining.
  10. Dockboy
    Dockboy Formula Junior
    610
    Maryland
    BIG CERT'S are awesome!
    I redid all of the head studs with them once in one of my twin turbo 5.9l Cummins diesel race motors. It pulled the threads on a couple studs and the block had a whole lot of specialized machining done to it so I figured I would try the BIG CERT's first before spending the money machining a new block. They held the head down with 1,800 hp and 110 psi of boost!
  11. miked
    miked Formula Junior
    Feb 7, 2001
    899
    Cincinnati, Ohio
  12. conan
    conan Formula Junior
    Nov 13, 2011
    389
    If I recall this correctly, the studs have different tighter tolerances to the block. Not sure it is a problem but good to know if making a stud on your own. It should be a tight fit in the block, but normal fit with the nuts.
