Timing Belt | FerrariChat
Timing Belt
Discussion in 'Mondial' started by porphy, Jun 25, 2012.
  1. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    #1 porphy, Jun 25, 2012
    Here is couple of photos of the timing belt removed from my Mondial T at the last major service. There are absolutely no markings on this belt. Is this normal? Do the markings come off after so much use? I thought that ISORAN (sp?) belts were clearly marked and that the marking stayed on. Are there Chinese knock offs of the Isoran belts or other manufacturers that do not mark their belts?
    Thanks in advance for any comments.
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Likely OEM, just been on the car so long that the marks are no longer visible. Nothing nefarious here...
  3. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #3 soucorp, Jun 25, 2012
    +1
    Note new belt with markings and note a used belt with rubbed off markings.
    This tells me that your belt probably stayed on longer than the recommended usage therefore rubbed off all markings.
    Do you know how many miles between belt service before your major was done?
    Here are some photos from Birdman Ferrari that backs up this theory!
  4. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    According to the PO the belt was changed at 39K. I bought the car at 43K about 5 years later. Funny thing is that there are absolutely no marks left not even at the edges where you can see from your photos that there are still faint marks. Just curious about non-standard sources of parts. Thanks for the comments.
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Maybe it was, maybe not...Then again, with the 348 engine, that's one long, long belt doing far too much! The wear factor will be greater than a 3x8 or BB.
    Great question, as there's a lot a junk out there being pedaled as OE. I've yet to see a knock-off timing belt, as the original ones are just not that expensive to begin with.
  6. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    +1 good point, that's the reason I asked. But I imagine anyone making belts (and there are lots of Chinese timing belt makers) could easily adapt to produce one of the proper dimensions. In Chinese marketing, I wonder if its not how big your broom is but how well you sweep the corners? Sorry for the off theme comments. Kind regards.
  7. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    I just replaced one of my belts for a leaking cam seal with a new Dayco from Ricambi. It had only been a year since I had done a complete service with the same belts and about 1600 miles and the markings were fairly worn though still legible. I don't think you have anything to worry about.
  8. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    I agree. There is a DAYCO Isoran in there now. So no worry. Only 4K on it and 1.5 years. Should be good for a while as soon as I can get it running on both banks!
  9. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #9 soucorp, Jun 25, 2012
    The real question is does anyone know or have heard of a timing belt snapping off? It could skip a tooth or two therefore bending your valves but do you know how hard it is to break/cut a timing belt? 3-5 years or 30k miles is recommendation for belt service.
    A timing belt is a transmission belt made from elastomers, having a flat outer surface with a number of teeth on the internal surface, widely used in internal combustion engines to control the valve timing. The belts are generally made from rubber with high tensile fibers, such as Kevlar or fiberglass, running through it. However, rubber's poor resistance to high temperatures has led to the development of timing belts made from highly saturated nitrile (HSN) that deliver significant resistance to high temperatures. Initially, the belts were designed with trapezoidal teeth, which suffered from high tooth wear rates. This has led to the development of curved teeth, which last longer and run quieter.
    Here is a great write-up I found about Ferrari Timing Belts.
    If your Ferrari was built since 1974, it is likely equipped with timing belts to operate the engine’s valves.
    Ferrari has issued specific instructions regarding the periodic replacement of these belts to avoid engine damage. This is because Ferrari engines are “interference engines”, meaning that if the valves were to become “out-of-time” due to a drive belt failure, insufficient clearance exists between the open valves and the pistons to avoid mechanical contact. In simple terms, this means that if a timing belt fails, the pistons will strike the valves, bending them and also inflicting damage to the piston crowns.
    To avoid this possibility, the periodic replacement of these belts is strongly recommended. Initially, published replacement intervals were based solely on mileage. Later, these recommendations were revised to include a time interval as well. This change was the result of incidences where belts had failed on vehicles with minimal mileage, but significant age. A Ferrari is typically used for pleasure driving and not daily transport. Consequently, infrequent use introduces an age issue with the belts. As belts age, dry-out, or become subjected to oil leaks, their performance is compromised. As stated earlier,
    should a belt fail due to these problems, severe engine damage will result. The typical failure mode of a timing belt is sheared “teeth”, which
    then cause the associated camshafts to become incorrectly timed. This means valves are open at the wrong time, when a piston is
    reaching the top of its travel. Ultimately the pistons strike the open valves bending them. Repair to the engine at this stage involves
    replacement of the valves, and possibly valve guides and pistons. The belt failure event is extremely quick during engine operation,
    and therefore no corrective action such as stopping the engine can be performed in time to prevent the damage.
    Furthermore, the compromised belt “teeth” are usually impossible to detect during preventative maintenance inspections.
    As a result, the recommendation to periodically replace timing belts is used.
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes, it has happened a bunch of times, including mine (previous to my ownership). There was extensive damage to one cylinder head.
    Also, there are several threads to support timing belt failures as well.
  11. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Hi Wade, so the belts were cut in two or was it the bearings/pulleys gave way and broken fence sheared the belts? Interesting to know how these things fail.
    Thanks for sharing.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #12 Wade, Jun 25, 2012
    Mike, it was reported that "a belt broke and fortunately it was at a stop light". The work order shows a "cam belt kit with bearings", however, the cause of the belt failure wasn't determined.
    BTW, this event occurred in 2002 which was before Ferrari issued their 3/30,000 document. At the time, the car had only 21464 miles, well under the 60,000 miles replacement interval as per the Owners Manual.
    Here's post from the other thread...
    Here's the entire thread - "How often to change 328's timing belts?"
    http://www.ferrarichat.com/forum/showthread.php?t=293315
  13. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,568
    Avvocato
    Nobody really knows the correct answer, the new assumption is, the belt breaks because of old, or worn tensioners. When the tensioner is worn, or the grease is dried they seize, and the belt then snaps ...hence ,the belts look like failure.
    Personally, I have gonE over 7 yrs and have been fine. The key is monthly use , start ups, small drives but constant. This keeps everything lubricated, and the belts from forming , and then tensioners working.
    I suspect , cars that sit for long periods of time, example, in excess of 3 months or more....this gives enough time for things to start to dry up...like the tensioners, and the belts.
    Just start your car every few weeks and this will solve many issues.
  14. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    These items are changed at every major service. No sense in allowing them to be the reason for catastrophic failure when they cost little in comparison to repair of bent valves and associated items.
  15. TheMayor
    106,059
    Vegas baby
    I know why there is so much anxiety here with this issue:
    People think: "the only thing between me and a blown motor and a ton of $$$$ is a rubber band running at 7,000 RPM's back there!"
    But, it's a really strong rubber band that lasts and lasts for years.
    I do agree that the tensioner bearings fail more often to cause a problem--- usually from a lack of use or water from excessive cleaning.
    How often did I change mine? Every 3 years just to be safe. YMMV. :)
  16. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    Must have happened in the history of my car at one point. 2 slightly bent valves needed changing when I rebuilt it 2 years ago.
  17. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I've extended my luck up to 9 years. Belts looked nice but a little harder than new. The tensionners were probably more than 20 years old at that time and one was making noise. I don't do this anymore. Belts are cheap and easy to replace and the tensionners too.
