I am familiar with the older Ferrari models and not so much the newer ones. Q--I heard that 430's and Italias are equipped with timing chains vs belts. If so, what is the the major service schedule like? I'm sure that it must be different than the old 3 year/30k mile major service for those with belts. Also--are 360' equipped with belts or chains? Just curious.
But 360 major service prices might be more "in between" a 430 and say a 355. The 360 was designed with a hatch between the seats to access the belts, tensioners and water pump. Both seats are removed and blankets laid out to protect the interior during the service.
Regarding 430s, there is no such thing as a "major service" in the traditional sense. Each year requires fluids and filters plus inspections. Oil and brake fluids are annual, the others every other year. Change the accessory belts when they look old which can be done from underneath. Spark plugs get changed at 30K. Dave
IIRC, there is a prescribed maintenance schedule (inspection and later replacement) for the chain tensioners on the later cars --- not sure about the details on that though. Is this correct?
Here is the rundown on factory recommended service for 2005 430s up to 120K miles: Accessory belts: inspect every 15K, adjust every 30K Oil: annual change Check timing chain: every 45K Cooling system connections and hoses: inspect every 15K Air cleaners: replace every 15K Fuel lines and connections: Inspect every 30K Ignition system cables and connections: inspect every 15K Spark plugs: replace every 30K Charcoal canister and O2 sensors: replace 90K Blow by system: Inspect every 30K Evaporative emissions: inspect every 45K Gearbox and differential oil: every 2 years Power steering fluid: every two years Brake/clutch fluid: change every year A/C replace fluid and filters every 2 years Alignment: every 15K Cabin filter: replace every year Inspect alternator and starter absorption: every 30K Replace air bad every 10 years Replace seatbelt pertensioners every 15 years. Otherwise calls for checking brakes, inspecting and tightening suspension, body and exhaust bolts, etc. Dave
