360 - Timing check | FerrariChat
360 Timing check
Discussion in '360/430' started by MR. JETSON, Dec 9, 2020.
  1. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  2. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    Is it the reflection on the shaft or is there a nice groove mark dead on? Based on your question, I'm assuming there is no marks?
    How did you get to TDC? Could you possibly be at "the other TDC". Is the mark on the shaft on the opposite side by any chance. i.e.8 o'clock instead of 2 o'clock on your picture? Maybe poste a slow video showing all around the shaft...
  3. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  4. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  5. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    I Cant see the scribed marks on the cams. I only see the reference marks on the caps. They can be hard to see and are hair thin. I like to use silly putty and take an impression.
    02360spider likes this.
  6. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,735
    Honolulu
    Kevin
    You can only check the marks at TDC as fotostars mentioned. The marks on mine were very hard to see and not a "line" but more like a wavy line made with a pin router or small engraver. My eyes arent the best but I needed a borescope to see them. If you have something small that can do good macro shots it may help.
  7. fotostars
    Feb 6, 2015
    345
    Bay Area
    Can't see any marks on those photos. Are the belts still on? Did the engine run before you opened? Is there paint marks on the pullies in the front of the engine?
    I'll be frank: When I did my major, I didn't open the back as you did. I know it's in the WSM to check but I figured my engine is running well so I marked everything in the front of the engine and swapped belts. All good...
  8. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    Completely legit. Lock and swap.
  9. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    I agree. Try the silly putty.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    This is 1-4 in time on a 360. In my garage right now.
    The scribe is dead center on the cam, and it looks to be in between the two flats.
  11. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    When I do a new-to-me 360, I always find TDC with a degree wheel and mark the position at the flywheel so that I don't have to do that again. Then I do the cam timing with the degree wheel to WSM specs and THEN I make new paint marks at the front cam pulleys so I can find my way back if lost.
    RANDY6005 likes this.
  12. yelcab
    Nov 29, 2001
    13,697
    San Carlos, CA
    Mitchell Le
    I just remember something. IF you are at TDC number 1 and your cams are like that, then they are off time by a lot. The flats on the cam ends are supposed to go into a factory cam holding tool in order to remove the cam variator at the other end. Therefore, they are designed to be in a certain direction like my picture indicated.
  13. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  14. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  15. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    919
    TX
    you shouldn't roll it back if you missed the marks. Just rotate it around again in the direction the crank spins and go slowly as the marks start to align
  16. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    If I game the vice grips off will the cams pop?
  17. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  18. 74dino246gts
    74dino246gts Karting
    Aug 6, 2004
    126
    Northern California
    It may be time to seek someone that has done this before to come over and help you, or take it to a professional. These are interference engines and incorrectly performing the cam timing can lead to disastrous consequences.
  19. fotostars
    Feb 6, 2015
    345
    Bay Area
    I had the vice grips slip off on me doing the 1-4 bank. The intake cams snapped a few notches. Had to bring them back and it was hard because you’re fighting the valve springs. Used the old belt and the crank to pull on it. Lock them again. Then bring the crank back to where it was supposed to be.
    Obviously only doable if you have good marks to start with.
    Next time, I’ll use a proper generic cam lock tool. The vice grips are a little too dodgy for me (even though it’s Ferrari’s recommended toll per WSM)
  20. RedNeck
    RedNeck F1 World Champ
    12,571
    The CSA
    Me
    I noticed there is no green dot on your variators...what year is your car, or do you have records of them being replaced?
  21. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    2002
  22. RedNeck
    12,571
    The CSA
    Me
    I would look into that then. Looks like you may have the old style variators.
  23. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    They’re OMGs, I have no records on the car, I’m putting together the records myself.
  24. RedNeck
    12,571
    The CSA
    Me
    Can you see the date code? There's tons of info on the forum about this. If they are the old style, you may want to consider replacing them.
  25. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Where would the date code be?
