360 - Timing check | Page 3 | FerrariChat
360 Timing check
Discussion in '360/430' started by MR. JETSON, Dec 9, 2020.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    In theory, that is true. In practice, it is not. You will find that there is no way for you to replicate the tight tension of the old belts after you have removed the old belts and put on a new one. The tension on the belts affect how many degrees you can turn the crank before the belts are tight enough to start turning the cams.
    Finding true TDC (and then mark it once and for all at the flywheel) gives you a way to get back to a known place.
  2. FiatAbarth850
    FiatAbarth850 Karting
    Aug 2, 2020
    100
    Winnipeg, Manitoba, Canada
    Bill H.
    Reading these two message portions, it makes me wonder if there was a bad or dirty connection on one of the sensors that was causing the CEL and if the connection problem was fixed when the sensors were swapped side to side? It would be nice if it was that simple.
    Happy holiday season!
    MR. JETSON and Qavion like this.
  3. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Well, I spilled a lot of coolant over the engine, maybe half a gallon or so, it may be that I need to clean the contacts with cleaner. I’m going to try that next. But no CEL still after the swap.
  4. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  5. FiatAbarth850
    Aug 2, 2020
    100
    Bill H.
    What are we looking at?
  6. FiatAbarth850
    Aug 2, 2020
    100
    Bill H.
    I kept on clicking trying to get rid of that "Wi-fi calling" box then finally realized that it was in your picture and not on my screen!
    kes7u likes this.
  7. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    what the hell are we looking at ?
  8. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,350
    Maryland
    Mark
    Looks like the TDC marks on the cams (rear side of engine). Presumably engraved after a wine-heavy lunch. :D
    MR. JETSON likes this.
  9. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    we already knew that. They tried twice to mark it, and missed.
  10. armedferret
    Mar 24, 2018
    1,350
    Maryland
    Mark
    Apologies, I appear to have misunderstood the question then when you asked what we were looking at.
  11. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    I was referring to an earlier picture way above. As for the last picture, I have no idea what we are looking at.
  12. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    Nice!
    Was this off by one tooth when you did the belt swap and fixed it by turning the offending cam one extra tooth? Or you corrected by degreeing the cam?
  13. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    OK, now I see what we are looking at. The first picture actually shows that the cam is out of time by a lot.
  14. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Just adjusted the cam and refitted the belt. Test drove and no CEL, everything checks for now.
  15. RedNeck
    RedNeck F1 World Champ
    12,578
    The CSA
    Me
    Minor? A "Minor" offset of that nature could potentially cause a hell of a lot more damage than just a CEL.
    Looks to me like a reflection on the first pic, and he just had it way off kilter. I only see the one timing mark.
  16. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Yes only the exhaust cam was out of time
  17. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    All inside the cam inspection cover rear of engine.
    Yellow line is reference machined valley mark on end cap. Blue is a scribed mark is on the cam.
  18. FiatAbarth850
    Aug 2, 2020
    100
    Bill H.
  19. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  20. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
