Timing gear ring nut socket | FerrariChat
Discussion in '456/550/575' started by dersark_painclinic, Feb 25, 2020.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
  2. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    What's the amazon link ?
  3. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
  4. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    should be posted in sticky!
    Nice info
  5. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    771
    san jose, ca
    steve
    what is that for again, can you show a picture of the timing gear control ring nut?
  6. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Steve, It is in the second picture, you need the socket to remove the special nut holding the timing gear in place,
  7. Cribbj
    Cribbj Formula 3
    Good find Sark! Can you post it in our Interchangeable Parts sticky thread?
  8. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    I cannot picture in situ. Is this on a 575?
  9. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Sure
  10. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Steve, 550, 575, table 6, item 14, part # 104919
  11. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    Thanks. I just did not have to go that far when I did the timing on mine..What issue would make you take that off?
  12. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I haven’t yet but in next couple weeks I will post the progress, the oil leak is the issue now, mean while I will replace the two bearings by hill engineering ones.
  13. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    Which bearings are those?
  14. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Steve, 550 and 575has the same bearings item # 2 part number 171177 updated by Hill engineering to better quality sold by Ricambi
  15. Ricambi America
    Sponsor Owner
    ^ I think there is some confusion here. In the above diagram shown by @dersark_painclinic , #2 is indeed 171177 but it is not a Hill Engineering item; its a standard SKF/Ferrari bearing. The Hill Engineering item is a lower cam bearing, 170787 which is drawn as #26 in the below image:
    We stock both items at Ricambi America.
    Qavion likes this.
  16. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I missed the diagram
  17. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    #17 stevepaa, Feb 29, 2020
  18. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    After you take the belt off try to wobble off the gear to see if it moves and has play, then you know it is time to change.
  19. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    I will check that next time I do the belts. thanks
  20. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    Do you plan to post pics of disassembly and reassembly when you do it?
  21. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Yes I will
    Prit Singh likes this.
