Tiny cotter pins in 308 carb linkage | FerrariChat
Discussion in '308/328' started by flyngti, Oct 26, 2009.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,219
    Snohomish, WA
    Eric L
    Anyone know where to find the sub-atomic sized cotter pins used in the carb linkage ends? Seem like I can only find pins locally down to 1/16" inch and the linkage uses ones way smaller than that.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I had one but I gave it away to someone here. It came with my carb rebuild kit and I did not use it. I would call up Pierce Manifolds, Gilroy, CA, but I doubt they would sell you just the cotter pin (it is so small it had to be taped to a piece of paper in the mail).
    What is wrong with just using a small wire?
  3. eracer
    eracer Karting
    May 29, 2009
    141
    Michigan
    Eric W.
    If you can't locate the cotter pins, safety wire works really well.
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Ditto...that's what I typically use.
  5. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,779
    Marin
    Geno
    i just replaced my ball/cotter pin set up with new linkage, i could probably find the wire if you really need it, but i would just use as suggested above (although some will complain its not "original" hahaha)
  6. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
