I purchased a set of 360 wheel for my 348 Spider. I also purchased a set of brand new tires Front 215-45-18R Rear 275-40-18R What would the correct tire preasure be for front and back ?? Brand in Hankook Thanks
Glenn- See if this helps for a starter, 29psi F, 32psi R, from this thread. You will probably need to do some experimenting, though, to get what you want. The first thread references a much longer, and funnier, thread. What it really comes down to, though, is if you buy an off-brand of tire and the manufacturer does not have a recommendation for you, you are on your own. Taz Terry Phillips http://www.ferrarichat.com/forum/showthread.php?t=280161
