Tire calculater | FerrariChat
Tire calculater
Discussion in 'Ferrari Discussion (not model specific)' started by MordaloMVD, Sep 27, 2007.
  1. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    #1 MordaloMVD, Sep 27, 2007
    This tire calculator is not protected, so be careful not to change the formulas. Use at your own risk. :) Obviously I have no way to calculate wheel clearance on your vehicle or rim diameter. General rule of thumb is that if the tire width is more than 1" over your rim size you are playing with fire.
    Hopes this helps.
  2. Ferrari Newspaper
    Aug 1, 2007
    38
    Asia
    Tifosi
    thanks... will study this and try to understand it.
  3. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Better than a rule of thumb, once you're ready to buy a brand & size of tire, go to the mfr website (or the Tire Rack usually has links to this stuff) and check the datasheet, it'll tell you the approved rim sizes.
    Also note that, with a load on it, the tire will roll about a smaller radius, so you can take that diameter and multiply it by about 97% to get the static loaded radius.
