Tire damage Question | FerrariChat
Discussion in 'Technical Q&A' started by moysiuan, Jun 24, 2017.
  1. moysiuan
    moysiuan F1 Rookie
    4,233
    Canada
    #1 moysiuan, Jun 24, 2017
    Is this sidewall divit from curbing on my daily driver just cosmetic, or will a replacement tire be required? Thanks for any perspective, never damaged a tire like this before.
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    Me, personally: I would drive on it (never over 75 MPH) until it starts loosing air. Then replace it.
  3. mello
    mello F1 Veteran
    5,514
    CA Bay Area
    Steve
    I had a similar damage on my F/L tire except it's more of a slash and is closer to the bead. I replaced it because I was afraid of a blowout due to aggressive cornering. Each to his own, but safety is always number one in my mind.
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Looks pretty cosmetic to me. Since it's a Mud + Snow tire anyway, I doubt if you're doing too much high speed "performance" driving on it. I would keep driving and monitor it for awhile both visually and air pressure-wise.
    QUOTE=moysiuan;145443920]Is this sidewall divit from curbing on my daily driver just cosmetic, or will a replacement tire be required? Thanks for any perspective, never damaged a tire like this before.[/QUOTE]
  5. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    First off why was my daughter driving your car?
    If car is used for shorter less highway I would keep it and put that tire on the rear if possible, In case of blowout. If anyone but you drives it or if you do a lot of highway miles I'd replace it. That's me. Any tire can blow out, and although this doesn't look deep, my guess is it would still increase the chance.
  6. moysiuan
    moysiuan F1 Rookie
    4,233
    Canada
    Thanks all, will probably replace as the car does get highway driven alot by others than just myself. Not worth worrying about.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Good decision as this is now a weak spot on the tire. With continuous flexing and temperature change it will eventually fail. Maybe after 1000 or 5000 miles but you don't want it to happen at highway speeds. A cheap investment.
  8. 3POINT8
    3POINT8 F1 Veteran
    5,381
    thats probably cosmetic. HOWEVER, i recently (last Sunday) got a flat on the front driver's tire of my F430. unreleated to this, the tire guy stated that i had a bugle on the sidewall that put the tire out of balance that caused burn around the side wall. this weakened the structure of the tire making it more susceptible to blowing out. i doubt that your nick would do the same but may want to change it before it does.
  9. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    +1
    It's not worth it. You don't want significant other, parent, child,, etc. stranded on the side of the road. The expenditure to peace of mind ratio is small. Since it's not a performance car, I'm assuming, you can replace one tire rather than a pair.
    T
