Tire exploded! Disaster averted | FerrariChat
Discussion in '308/328' started by Dave Bertrand, Oct 20, 2022.
  1. Dave Bertrand
    Dave Bertrand Formula Junior
    824
    Castle Rock, CO
    #1 Dave Bertrand, Oct 20, 2022
    Went for a drive yesterday, and ran over something causing my left rear tire to blow out violently. POW! Scared the bejeezus out of me. Fortunately I was only about a quarter mile from home, so I could walk back and get my spare (which was in the garage at the time) and my jack. It's a Continental Extreme Contact Sport with about 350 miles on it.
    An important thing I found out that I hadn't considered before is that when a rear tire is completely flat, you can't get a jack under the side factory jacking point to lift it up. I had to go back home a second time to get a piece of 2x12 to drive the rear tire up on in order to get the jack under there. From now on, I'm keeping that square of 2x12 in the trunk. I was using my ultra-low floor jack without the hockey puck. If I had to use the factory scissor jack it might require 2 of the 2-bys.
    Fortunately I was only going about 25 when it happened. I shudder to think what would have happened if I was doing 70 on a twisty mountain road.
    It also took a bite out of my newly powder coated rim.
    JuLiTrO and RodC328gts like this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Fortunate indeed, glad you’re ok and got your car home safel.
    Albert-LP and Thomas Magnum like this.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Wonder what you hit that would cause such a catastrophic deflate at such a low speed. Were you able (or interested enough) to look around to see what it could have been? I can't think what could cause that sort of damage at low speed - defective tire?
    Hmm.. it IS the USA, did you make anybody in the neighborhood mad enough to take a shot at your tire? :eek:
    moysiuan likes this.
  4. Octonion
    Octonion Formula Junior
    Dec 30, 2020
    344
    Glad everything is under control. How old was the tire?
  5. Dave Bertrand
    824
    Castle Rock, CO
    It was only 7 months old. I didn't go back to see what I might have run over, but there is a TON of new housing construction going on right in the area so there is probably debris on the road from all the trucks.
    I have a Ferrari so maybe a jealous neighbor took a shot at me. If I shake the tire maybe a bullet will fall out ;)
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Carefully inspect the other 3 tires.
    Dave Bertrand and Thomas Magnum like this.
  7. Octonion
    Dec 30, 2020
    344
    I would not let this go. Report it to the NHTSA with details from the tire. If there is a pattern, the NHTSA will kick off an investigation. Save the tire so it can be used for forensics if needed
  8. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    That is a very uncharacteristic failure for 'normal' road debris. I am reminded of the Firestone 500 carcass failures in the early '80s when I see your photo graph. I've run over a lot of strange things over the last 45 years, but never had a failure/blowout that looked like that.
  9. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I know you said the tires had low miles, but how old are they?
    miurasv likes this.
  10. Dave Bertrand
    824
    Castle Rock, CO
    Look up to post #5. ;)
    thorn likes this.
  11. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    412
    Pacific Northwest, USA
    Dave W
    #11 ChevyDave, Oct 20, 2022
    More bizarrely, how did you miss it with your front tire?
    Also, this: “An important thing I found out that I hadn't considered before is that when a rear tire is completely flat, you can't get a jack under the side factory jacking point to lift it up.”
    The 308’s ground clearance continues to amaze me. I’ve owned multiple X1/9s and a Lancia Scorpion and none of them had as little ground clearance as the 308 does. When I read about folks wanting to lower their ride height, I’m like “Jebus, I can’t even get a catch-pan underneath the engine to change the oil at the stock ride height; what would I do if I lowered it; slide a couple sheets of extra-absorbent Bounty paper towels under the engine?”
  12. bitsobrits
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    It's the body on frame design (vs a monocoque) that has such a negative impact on clearance, I think.
  13. built2grind
    built2grind Formula Junior
    Oct 16, 2016
    419
    The Peninsula
    ANDREW
    All I could say is OUCH!
    I had a similar sidewall blowout years ago, not in my 308 but rather a Ford F-250 truck at about 75mph and let me tell you it makes a sound you don’t want to hear.
    Glad you made it safely to the shoulder and was able to get the car home. Carrying a piece a 2x4 around is a good idea, it’s a way of life for me.
  14. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    #14 ginoBBi512, Oct 20, 2022
    Cmon, this stuff happens all the time, the tire has nothing to do with it, he ran over something, its that simple. There is so much ****ing **** on the roads here in the states, Im not surprised at all , Lets start an investigation , good grief. I cant tell you how much **** falls off of trucks, whether from construction sites or not, mad max scrap metal scavengers , who the **** knows, theyre everywhere. Between this crap and the jerk off drivers all over hells half acre, I dont even drive my Ferrari much at all, its a real ****ing shame what this land has become, I will leave it at that .We should all buy Porsches, and park our Ferraris in the garage, they are not as pretty, when they get ****ed up, take them to the body shop and dont sweat it lol .Im glad whatever it was , did not snap / bounce up and really **** up your Ferrari !!
    Big G
  15. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    Thank God you're OK!!
  16. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    That nick in the rim shows it hit something solid.
    Brian Harper likes this.
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    I can't think what sort of debris you could hit at such a low speed that would "split" a tire like that.
    Albert-LP likes this.
  18. Albert-LP
    Albert-LP F1 Veteran
    8,175
    around Modena, Italy
    Alberto Mantovani
    I don't think that a debris can destroy in such a way a tire at 25 mph withouh feeling a hit at the car, any shock, any car jump. I would say that's 100% a tire fail: it was a bad new tire, let's have it inspected by a technician.
    Ciao
    moysiuan and Octonion like this.
  19. Octonion
    Dec 30, 2020
    344
    mike996 likes this.
  20. Octonion
    Dec 30, 2020
    344
  21. ginoBBi512
    3,535
    SO CAL
    GINO RUGGIERO
    No way it a tire failure, are you kidding me look at the ****ing wheel for Christ sake, he ****ing ran over something, good grief Charlie Brown.
    Big G
  22. Dave Bertrand
    824
    Castle Rock, CO
    Yes, I ran over something. It was not just a tire failure. Thankfully there's no damage to the body or paint or any of the other tires/wheels that I can find.
    The biggest takeaway is that changing a rear wheel and maybe a front one on the side of the road, or even in a parking lot, is going to require more than your spare, jack and tool kit. If you don't have something to drive the wheel up on, you're gonna be SOL.
  23. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,945
    Melbourne, Australia
    Carl
    I think the OP was referring to the date code on the tyre, not the purchase date.
  24. Dave Bertrand
    824
    Castle Rock, CO
    The tire's been replaced already, but the other three are all from mid-late 2021 so I'd guess it's in that vicinity.
    carl888 likes this.
  25. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,945
    Carl
    I'm not sure if any posters are tyre engineers, however the nick in the rim suggests that something sharp and forceful hit the rim and tyre. The impact could have initially been just a few mm long, the resultant weakening of the carcas allowing the fracture to continue radially. Just a theory. Be interesting to have an engineers opinion.
    As long as you are OK and the car and other road users were not compromised, it's a win.
