tire inflator | FerrariChat
tire inflator
Discussion in 'Technical Q&A' started by KenGoldman, Feb 17, 2014.
  1. KenGoldman
    KenGoldman Formula Junior
    600
    MASS., USA
    Kenneth Goldman
    Since the cars sit in the winter, I always need to add air to the tires every month or so
    Does someone have a recommendation for one of the tire inflation machines or digital gauges that are on the market today??
    I have seen the Astro Pneumatic, the Branick, the PCL, etc all on e-bay
    Any help would be greatly appreciated.
    Thanks,
    Ken Goldman
  2. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Don't spend fifty bucks on a "tire inflation machine". Go to your local DIY store and buy a small, genuine, air compressor with a one or two gallon tank. It will cost you around a hundred bucks. However, you'll surprise yourself with how often you can use a blast of air from a real compressor, even if it's a very small one. If nothing else, you can inflate balloons for your next party.
  3. JCR
    JCR F1 World Champ
    10,898
    H-Town, Tejas
  4. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,781
    Weston, MA
    Paul
    I just bought this model a couple weeks ago at Sears.
    Sears.com
    I did a lot of research online and this model seemed to get the best reviews by users. Keeping in mind I just wanted a small lightweight model, as I'm sure there are much better compressors. Apparently there is an identical model marketed under the Goodyear brand name. I've only used it once so far, but so far so good. The only thing that disappointed me is the coiled hose was rather stiff, inflexible. Now this could be in part because I used it in freezing temperatures. Maybe in warm weather it will be much more flexible.
    I liked the fact that the tank held air pressure so if I wanted to top off a couple tires, I didn't need to have the compressor plugged in. There was enough pressure to add a few pounds to several tires.
    One reason I got it was it came with a normal tire air chuck rather than the lever clamp type. My previous inflator (MVP) worked well for many years, but the lever clamp got to be a pain to use as it started to wear. Although I shouldn't complain as I used it for something like 18 years on multiple cars. Hey, nothing lasts forever.
  5. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    I have exactly the same Campbell Hausfeld model for the last few years. Very light and portable. No issues so far.
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #6 Wade, Feb 18, 2014
    I received this for Christmas but still haven't been able to install it yet (house renovation comes first).
    Seems pretty cool!
    [ame=http://www.youtube.com/watch?v=qEy3vveB6MI]Chamberlain Garage Power Station - YouTube[/ame]
  7. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,940
    I agree. You can use a compressor for so much stuff you will be amazed. Bigger is better, as you will use it for cleaning stuff etc.
  8. Nospinzone
    Jul 1, 2013
    7,781
    Weston, MA
    Paul
    Wade, I saw ads for that and it looked to be very handy. The only thing I question about it is since it is so small would it inflate tires in a reasonable time.
    Vince, I am hoping the CH compressor I bought will generate enough air pressure to blow dry my Harley. However, the way the winter is going here, I won't know that until sometime in June. :(
  9. moysiuan
    moysiuan F1 Rookie
    4,184
    Canada
    There are some small practice dental compressors that are great for the shop. Key is they are very quiet and portable. My dad has one, I think SMT brand, Chinese made but pretty darn good quality. I got a larger one for my son who prepares fossils using dental air tools. Otherwise, for simple tire inflation I really like the campell hausfeld model rpa420000 120volt inflator. You set the digital read by a Knob to the pressure, and it pumps to the setting. Much faster than a 12 volt one, very compact unit. Got off ebay a couple years ago, must still be available.
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #10 Wade, Feb 18, 2014
    I'm sure it's okay for topping off car and bike tires. I've been using a 1 gallon Powermate for years. But, as suggested already, a 3.5 gallon+ would be more suitable.
    For my bikes and after carwash drying I use a blaster, works great!
  11. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    If you want to really kick butt drying your car get the Master Blaster by Universal out of New York. That thing has two 4hp motors and really does the job. I have had one for four years and it was one the best $300 tools I have bought. Warning, this thing has two motor controls and you can't flip them at the same time, it will blow a 20 amp breaker.
  12. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,680
    NJ
    Peter
  13. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,680
    NJ
    Peter
    This looks really good. I've used a leaf blower to dry the car, but it is so ungainly to handle that usually don't pull it out. Reviews say this blaster is much better than a leaf blower, so I wish I had known about this before I got the blower. The other issue I've found with the leaf blower is it doesn't really seem to dry the car as much as it just moves water around -- is this blaster any better in terms of actually drying the car?
  14. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
  15. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Not really a dryer but it does a great job of blowing out the water from crevices, around trim and louvers. And from motorcycle engine cooling fins as well.
    BTW, it's pretty loud.
