Tire Jell MESS | FerrariChat
Tire Jell MESS
Discussion in 'Technical Q&A' started by Zipy, Oct 17, 2007.
  1. Zipy
    Zipy Rookie
    Apr 19, 2006
    40
    Independence, MO
    Gary L. Perry
    I just used Black Magic tire jell on my tires. Let it dry overnight as per the directions. Went on a group drive with a total of about 300 miles. Now I have a huge mess all over the sides of the car. I don't think I used an excessive amount. Maybe it was the autobaun speeds we reached, who knows. Anyone know what works best to remove this crap from my tires? It seems very resistant to most everything I have tried. Thanks in advance. Gary
  2. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    I had the same thing happen to me Gary. I used a combination of Simple Green and a citrus orange cleaner I purchased at Lowes/Home Depot. Hose the tires down with as much pressure as possible. Get a bucket of warm to hot water and a stiff bristle brush. Spray the tire liberally with the cleaners (each from their own spray bottles), dip the brush in the bucket of water and scrub away.
    BTW, I now use the Eagle 1 tire gel with the "cupped" foam applicator pad on top. After I've applied the gel and it sits for a couple hours (depending on temperature) I get a damp sponge and lightly wipe the tires. The best results are obtained with the tires absorbing direct sunlight for a period of time.
    HTH,
    Brian
  3. sindo308qv
    sindo308qv F1 Rookie
    Nov 1, 2003
    3,575
    miami.fl.
    sindo
    Forget the jells, use Lexol rubber protectant. It leaves a natural
    gloss to the tire,no run off. If you go for the hi-gloss look
    use Meguiars.
  4. sindo308qv
    Nov 1, 2003
    3,575
    miami.fl.
    sindo
    3M makes a tar/adhesive remover that's very good, try that.
  5. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,034
    Summerfield, NC
    Tom Jones
    Charlie's Soap. You won't believe how well this stuff work. We use it on everything around the shop. It is also great for cleaning parts. (I'm not associated with this company) http://www.charliesoap.com/
  6. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    Try CRC Brake Clean, it will take it off. Just spray it on and wipe off, done deal.
  7. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    same exact thing happened to me
    that stuff is crap
    i never used it again
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Aerospace 303 is the best product I've found.
    Gives items treated a new look without the fake, glossy shine.
  9. bst1
    bst1 Formula 3
    Aug 13, 2005
    1,055
    MARYLAND
    BARRY T
    Best product I have used is "Wheel Wax Extreme Black". Non-greasy, NO fender splatter, makes tires look brand new, not shiney, even smells great!
    www.wheelwax.com. same company that makes "WheelWax" which I also recommend to help repell brake dust on wheels.
  10. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    sounds to me like you may have put it on way to thick. I us minimal amounts and rub it in till it's almost dry. But then again I don't want my tires to look like mirrors!
  11. Zipy
    Zipy Rookie
    Apr 19, 2006
    40
    Independence, MO
    Gary L. Perry
    Thanks for all the advice guys! Gary
