Tire placement question | FerrariChat
Discussion in 'Technical Q&A' started by miketuason, Mar 11, 2015.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,825
    Cerritos, CA.
    If you have four tires two brand new and two 50% worn, where would you put the two brand-new tires, front or rear on the front wheel drive car?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,700
    South East
    Jimmie
    Brand new tires on the front of fwd
    Firstly because thats where the best grip needs to be and secondly because thats where (as a result) most wear should take place
  3. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Thank you the reason I'm asking is because this tire shop said it should go on the rear they said that's as a rule they always put the new one on the rear end. they will not put it on the front for me so I guess I have to switch it myself
  4. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Vote with your feet, if the merchant will won't do what you want. It's your car and your money. Just tell him "AMF". Same with elected politicians. I hope that this is of some use to someone. Jq.
  5. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    This is their explanation they said the reason for this is that you don't have control on the rear in case something happen but on the front, you have some controls even if the tires are worn out. I don't like this explanation to be honest.
  6. NoSpeedLimit
    NoSpeedLimit Karting
    Sep 6, 2013
    185
    I found an article on the internet (unluckily only in German) with test results from Michelin. Under critical driving conditions (breaking in curves when the tarmac is wet, aquaplaning etc.) cars with a rear drive are better controlled if they have the newer tires on the rear axle.
  7. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    I agree with this statement for the rear wheel drive as the traction is/are at the rear but not for front wheel drive.
  8. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,679
    Palo Alto,CA,USA
    Walt Kimball
    Motor Trend did some testing on this issue in the May 2004 edition. Result: Always put the new tires on the rear,whether fwd,rwd,or awd.
  9. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Ok thanks Walt, that's an interesting study or testing.
  10. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    When I was young and poor I had a hot-rod Scirocco. And I has worn those front tires down pretty far by, uh, spirited driving. Not bald, but in the wear bars for sure. The rears were still in good shape though. So I swapped them. Made sense to have the tread in the front, right? A couple of days later my girlfrend and I are just cruising along and it is just barely raining, the road isn't really wet yet, just damp, and I'm not doing anything stupid - it was a rare moment, but they happened occasionally. There was the slightest bend in the road, you might not even notice it. It is a divided four-lane road with moderate traffic. I entered this slight bend and the back end of the car came around slowly and super smooth. My girlfriend was looking down, I think reading something in her lap. She didn't even notice the rotation. She only looked up after the first 360 because my hands were going crazy trying to steer the car into the skid. The second time around we'd slowed pretty well. We'd spun twice fully around, wound up pointing the right direction and if it weren't for the left turn pocket we would have spun over the double yellow into on-coming traffic. We stopped perfectly in the left turn lane facing the right way. I made a U-turn back home and we took her car.
    So yeah, good tires in the rear.
  11. greyboxer
    Dec 8, 2004
    12,700
    South East
    Jimmie
    OK - happy to learn but would appreciate any links to tests
  12. afterburner
    afterburner F1 Rookie
    3,496
    Switzerland
    Urs STEMMLER
    Regardless of driven wheels - in an emergency (off the gas and maybe on the brakes) or at the limit in a turn (wet, a cat running out), you do not want the rear to step out. So put the better tire at the rear. This is precisely the reason why there is also brake pressure limiter at the back - you never ever want to lose traction in the rear before the front lets go. Your tire shop's advice is safe and industry standard. Also, if you have older and newer tires, always put the newer ones at the back.
  13. Jdubbya
    Jdubbya The $10 Trillion Man
    43,496
    PNW
    Really screw with 'em and ask to put them kitty-corner. ;)
  14. Redneck Slim
    Mar 10, 2011
    1,679
    Palo Alto,CA,USA
    Walt Kimball
    That is what the M/T testers found: unexpected snap oversteer in the wet that even professional testers couldn't catch.
  15. dm_n_stuff
    Dec 10, 2003
    43,844
    26.806311,-81.755805
    Dave M.
  16. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    It was so smooth I'm not sure "snap" describes it. Knowing what I know now I'm sure I made it worse by letting off the gas and/or trying the brakes. Probably giving it some gas would have straightened it out. I certainly didn't have the knowledge or skill and I might not have had the time or the room. I would expect a professional driver in a controlled situation to be able to save it, interesting they couldn't. I would expect a civilian driver on a public road not expecting it, to spin - at least twice...
