Is "Low tyre Press" supposed to come on after each time you start the engine?
No, it is not normal. Check your tire pressures when cold, since you are having this problem, I would recommend checking them after it sits overnight. The cold pressure should be set to the PSI on your decal that is mounted on the door jamb. This should fix your problem.
