Tire Pressure Monitoring System on 2004 360 Spider | FerrariChat
Discussion in '360/430' started by Keith360, May 29, 2015.
  1. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    Hello, I believe I have Tire Pressure Monitoring Transducers in my car but nothing alludes to having them on the inside of the car. The valve stems look like TPMS Transducers.
    The car: 2004 Ferrari 360 Spider F1, 13,500 miles, 19" Challange Wheels, original tires which look good but uneasy driving until I change them out.
    I'm in the process of choosing a new set of tires and want to be prepared during the tire change to also get a TPMS up and running.
    I think I see that a TPMS was available on the 360, evidence in parts manual online, but where should the information display?
    Possibilities:
    1. The car has the system with transducers on the wheels and antennas in the well house and I'm not seeing the controls or information inside.
    2. Car has transducers and previous owner had a hand held device or used an app on his cellphone.
    3. Wheels came from another car that had a TPMS installed either OEM or after market.
    I have the original window sticker and a TPMS is not listed. i can't recall if the 19 wheels were listed on the window sticker. I don't think so because the tire pressure chart in the right door shows 18" data and no 19" data.
    I think the app for my iPhone would work for me the best. I found some companies that sell kit with transducers that screw onto the valve stem, but that look is not for me.
    The communication between the xducers and the iPhone on these aftermarket systems seems to be Bluetooth. I wonder if the free app would talk to my xducers?
    I think the first thing I should do is go down to my local tire shop and talk tires and xducers and see if they can interrogate the xducers. I have a couple of apps installed on my iPhone and with the xducers address or serial numbers I could see if the app would work.
    Any thoughts please...
  2. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,100
    Calif
    Brett
    that is because you don't have them...at least my 2004 doesn't...was that an option?
  3. Chrisnlbc
    Chrisnlbc Formula Junior
    Jan 9, 2015
    374
    Huntington Beach
    None here on my 2004 either.
  4. Keith360
    Feb 6, 2015
    570
    Keith Williams
    #4 Keith360, May 31, 2015
  5. pietro
    pietro Karting
    Dec 24, 2011
    64
    So Cal
    No they look like Just normal metal valve stems.
  6. Keith360
    Feb 6, 2015
    570
    Keith Williams
    #6 Keith360, Jun 1, 2015
    Sure looks like the TPMS Xducers to me. See photo attached.
  7. Keith360
    Feb 6, 2015
    570
    Keith Williams
    #7 Keith360, Jun 1, 2015
  8. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,435
    On the Limit
    Dino
    360's did not have tire pressure monitors as standard or an option.
  9. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    That may be, but the oem Ferrari stems have the nuts on the outside. I know of no 360 that came with TPMS stock.
  10. Keith360
    Feb 6, 2015
    570
    Keith Williams
    #10 Keith360, Jun 2, 2015
    I retract the statement that I saw TPMS hardware in the parts manual, When first researching I was leafing between the 360 and the 430 and looked again just now and the TPMS hardware was only in the 430. But the transducers look like any other TPMS xducer with the bezel nut on the outside.
