430 - Tire pressures for 20” wheels ? | FerrariChat
430 Tire pressures for 20” wheels ?
Discussion in '360/430' started by West Point, Nov 26, 2019.
  1. West Point
    West Point Karting
    Oct 21, 2019
    57
    West Point
    I see a good deal of chat here about tire pressures, but these all seem to relate to 19” wheels. Does it make a difference if the car is fitted with 20” wheels or do the same pressures apply equally to both 19” and 20”?
  2. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    709
    EL PASO , TX
    JASON
    Popcorn in hand....waiting to hear the science behind this :D
  3. tazandjan
    39,169
    Tire pressures recommended by Ferrari are empirical, they tested them to get the best pressures for that combination of model, wheels, and tires. With non-OEM wheels and tires, or even with different from recommended suspension settings, the best you can do is make an educated guess around Ferrari's recommendations. It is then trial and error to get pressures that make her handle like you want her to. Science does not help here as well as an educated rear end.
    Need4Spd likes this.
  4. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Best way is to use a probe temp sensor to test inboard, center, and outboard portions of tires when hot immediately after you come off the track.. That is the way it is done at the track. If you do this after a normal drive on the street and get big differences in temps you were way off pressure, or alignment wise. On the street, get it in the ballpark. If you are driving crazy and you spin, pressure too high? To low? Maybe just driving crazy on the street?
  5. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    this forum never disappoints
    Eric C likes this.
  6. Bill ochrane
    Bill ochrane Karting
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    OMG! I've been doing it wrong for over 50 years.
  7. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    or you could just put 30-35 and go about your merry way :D
    Eric C likes this.
  8. Eric C
    Eric C F1 World Champ
    11,063
    St. Louis, MO
    Eric
    or maybe look at the side of the tire lol
  9. tazandjan
    39,169
    Side of the tire only has maximum recommended pressure for the tire. Riding around with the tires set at 50 psi is not going to do much for handling, braking, or tire wear.
  10. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
  11. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
  12. tazandjan
    39,169
    Jason- Might work, might not. If all you do is trundle around in a straight line at low revs, close enough.
  13. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    From the original post , it doesn't sound like this question is based on hitting the track . I have played with air pressure in mine and i can tell you that the TT setup will cause tire spin with low and high pressure . I run 30 and it works for me....and my car does more than trundle in a straight line at low revs .
  14. West Point
    West Point Karting
    Oct 21, 2019
    57
    West Point
    The TT setup ?
  15. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
  16. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    I like 30-32, unless you going long high speed, then maybe 36
