Tire Pressures in 355 | FerrariChat
Discussion in '348/355' started by butcher, May 20, 2010.
  1. butcher
    butcher Formula 3
    Oct 19, 2008
    2,339
    Castro Valley, CA
    Albert
    What tire pressure do you guys run on your 355 with stock 18 inch rims? Do you follow the recommended pressures of 32psi fronts, 29psi rears as noted on the right doorwell. Aren't these pressures for the original Pirelli PZero's? I have Michellin PS2's 225/40 fronts, 265/40 rears and use the as mentioned recommendation on my doorwell. One shop that did my service recommended higher tire pressures: I believe it was 40psi fronts, 45psi rears.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,709
    South East
    Jimmie
    #2 greyboxer, May 20, 2010
    You probably need a new shop - they sound almost dangerously high
    There are several other threads here with a range of answers from 27f/31r to 36 all round with 32 to 34 all round as the most popular
  3. race850i
    race850i Karting
    Jan 6, 2010
    132
    Germany
    Themis
    In the Owners Manual you will find the right pressure for the 4 Tire types that Ferrari recommends!
  4. ricardo teixeira
    ricardo teixeira Formula Junior
    Sep 2, 2009
    356
    Luanda / OPorto
    Ricardo Teixeira
    I should confess that I was very much suprised with the diference on pressures for OEM tires for the 348.... from Bridgestone to Pirelli.... never would believed that would be so much diferent!!!
    But the original stickers do not lie!
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    With Bridgstone S03s I run 35 PSI for the street and 32 PSI for track driving. This puts the tire at 38 PSI when warm on the street and 40 PSI when hot at the track.
    With the Bridgestone RE050A PPs I am running 34 PSI front and 33 PSI rear on the street.
    The ONLY real way to tell if you are running the right tire pressure is a Probe Tipped Pyrometer and measure the actual tire temperature profiles under actual drivinig conditions. Its not a <pick a number from the table> kind of game. The right tire pressures vary based on driving style, road surface and ambient temperatures.
    If yo don't have a probe tip pyrometer, read your tire pressures after along run. You want them above 36 PSi and below 40 SPI. But the sweet spot is rather wide, wth softer responce characteristics on the soft end and sharper responce on the firm end.
    After you find the operating pressures YOU like, put the car in the garage and come back the next day to measure the cold pressures you will want henseforth.
  6. tazandjan
    39,318
    Albert- The 99 OM recommends 27 psi F and 31 psi R for Michelin Pilot SX MXX3 tires. Probably a good starting point. The PS2s did not come out until later. For the 360 with similar weight distribution and Michelin PS2s, recommended pressures are 26 psi F and 28 psi R. So 27 and 29 or 30 might be a good compromise. A little fine tunig should get you even closer.
    Those PS2 pressures are consistent, by the way, even if they seem low. On my car PZeros use 32 psi all around and Michelins use 29 psi all around, and my car weighs 500 lbs or so more than yours.
    Taz
    Terry Phillips
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I use around 33-35 psi in all tires when I want good mileage. I drop about 4-6 psi when I want to tear it up. I also use the same pressures all around. Never understood the reason for different ones except to induce some oversteer, which means the factory feels they built in too much understeer with their stagger.
  8. butcher
    butcher Formula 3
    Oct 19, 2008
    2,339
    Castro Valley, CA
    Albert
    Excellent responses everyone. I never realized that recommendations for the Michelins, Bridgestones, Pirellis, and Goodyears were all in the owners manual until I read responses to this thread. It really is interesting how different each of these tires and recommended specs are. Now time to tinker a little. F-chat rules!
