Tire size for 360 on 20's | FerrariChat
Discussion in '360/430' started by toussi1, Jan 5, 2017.
  1. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Friend has a 360:
    20x9
    20x11
    Wheels, what tire size is recommended for a 360 without rubbing?
  2. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    If it's stock height, it will rub rarely and only when doing a fast tight turn or going up curbs while the wheel is steered left or right. If the wheels are straight even on high speed it won't rub.
    I have 20s on my lowered 360 and it's fine. Just a little mindful driving would do.
    The only way it won't rub up front when your on 20s is if you have stretched tire which is not recommended. It's like those slim tires you see from hondas or toyotas that have their wheel camber completely off. That's how they prevent them from rubbing even though their tire is so close to the fenders.
    If it's not lowered and you have 35 series back and 30 front tires your fine. Just little rub once in a blue moon which is not a biggie.
    I'll check the exact measurements on mine later when I come home but this gives you an idea what to expect.
  3. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Thanks, does this look right?
    Front: 245/30ZR20 (90Y) XL
    Rear: 325/25ZR20 (101Y) XL
  4. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Im running 345/25-20 at the rear. Both on 360 and F430. But Im running 19'' up front. 255/30-19.
  5. toussi1
    toussi1 Karting
    Jun 10, 2007
    160
    Wow! 345, that is insane. The car barley has enough torque to break traction as is.
    Anyone else Please chime in what 20" tires you are running. PLEASE
  6. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    I will later when I arrive home. Last night I fell asleep and forgot. Lol
  7. acmw
    acmw Formula Junior
    Apr 28, 2006
    575
    Nj
    Alex
    did you roll your fenders on 20s?
  8. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    My 430 came with 19s up front and 20s in back. Tire sizes were
    F: 245/35
    R: 345/25
  9. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    In fact, I have a set of 19'' as well, with 355/25-19 rears. About as wide as it gets......
