Tire size for 360 wheels on 348 | Page 2 | FerrariChat
Discussion in '348/355' started by emailben, Mar 9, 2014.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 .......... I think 295s would indeed be too wide for your combination .... that 'at the limit' offset is what I recall seeing in the past with those 360 wheels .......... what year is your 348?
    Maybe an early 348 owner with 360 wheels can chime in with some pics? :)
  2. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    I have the same setup and love the way it fills in at the front of the rear fender but the back sticks out a little to much.
    There are some very talented people out here, I can't believe someone hasn't modified the rear bumper to accommodate the tires. Just a little flare would make it look ecstatically pleasing and functional.
    I never had my wheels modified because of the trade off. Even with the stock wheels, they stick out a little in the back but way too far in on the front. Just my opinion. So, I just deal with it, and it has grown on me.
  3. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    1990 348tb
  4. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Mine is a '92 but pre increased offset. I used to run the 25mm spacers with the stick wheels but removed them for the challenge wheels.
    Kai
  5. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I would have to revert to my original opinion ..... :)
    225/40-18 -- front
    285/35-18 -- rear
    These sizes ^^ make the 348 look flatter and wider ...... which goes along with its body style ... :cool:
    IMO, stock 360 tire sizes are too 'tall and chunky' for the 348 body style ...... :eek:
    Yeah, I could see why you took the spacers out ... 25mm would be too thick for that combo ........ I think 11mm spacers would be perfect though .... :)
  6. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    #31 driveitdaily, Mar 11, 2014
    I made a mistake in my earlier post , my rear size is 275/35/18, and stock (225/40/18)355 size up front, lower the car a little and those sizes seem to look perfect,rears don't look too chunky , wide , but low profile.
    " serenity now "
  7. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I thought 275/35-18 will make the 348 look even more flatter?
    stock 360 tires is 26.7" diameter.
    275/35-18 is 25.6" diameter.
    285/35-18 is at 25.9" diameter.
    Going with 285 is only making it 0.8" flatter. while 275 will make it 1.1" flatter.
    Maybe I should go with 275 to be on the safe side as it give more wheel arch clearance?
  8. driveitdaily
    Jul 20, 2013
    1,041
    john
    we lowered the car a little more in the front than the rear to give it a little rake and it looks perfect
  9. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Yes the 275/35 is even more flat than the 285/35 ...... my original 'flatter' comparison was against the stock 360 tires of 275/40.
    The reason I like the 285/35 is because it gives the 348 a slightly more modern look (a tad bigger on the rear ... but not too big ;) ) ..... also I have seen that 285/35 size used on several 348s and it looked near perfect for the 348 IMO ..... but the difference between 275/35 and 285/35 .... is not really much .... .3" diameter or 1.5" difference around the perimeter of the tire.
    Looks like there was a lot of good info posted by everyone and it seems to have helped make your decision ....... :)
  10. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    What tire pressures do you put on your 360 wheels?
  11. nismodrifter
    nismodrifter Formula Junior
    Jun 11, 2008
    548
    YYC/YVR
    Navdeep
    Wow. Looks amazing!
  12. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I think my final decision is to run 225/40/18 in the front, 285/35/18 in the rear.
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    You will not regret it ........ that combo looks very well balanced to the 348 IMO .... be sure to post pics! :)
  14. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    #39 dahveedem, Mar 13, 2014
    I always wondered if I had the right tires on my car... I'm running 360 wheels which were "cut" for the car. The OEM wheels (which I have) seemed to fill out the wheel well a bit more ... a look I actually prefer.
    I'm in need of new tires for the rear and was about to pull the trigger on the same size.. glad I saw this thread.
    Currently it has
    255 /40 18 on the rear
    215/45 18 on the front
    Mine barely reach the edge of the wheel well. I'm thinking I can go with bigger tires...
    Thoughts?
    btw '93 speciale if that makes a difference
  15. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    Yeah, i can see you need a little more rubber on the back from looking at the sidewalls. I think those wheels should have stock 275s on them. Those wheels look great though!!
  16. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Good looking wheels :) ......... it looks like they 'cut' a tiny bit too much off the rear :( ....... do you know if these wheel widths the same as stock 360 star wheels?
  17. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    #42 dahveedem, Mar 13, 2014
    Not sure previous owner cut them. Been thinking about spacers for the rear to bring them out a bit.. but 15 mm might be too much.not sure what size tires to run either.
  18. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    so i think I'm going with 275/35/18 on the rear and 225/40/18 on the front.
    now to figure out the brand....
  19. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I just bought a 348 with 360 wheels on it. 215/45/18 front and 275/40/18 rear. The PO said he did not machine the back of the hub (sucking it into the wheel well). He ran the car about 1500 miles with that set up and I see no evidence of tire rub any where.
    I'm convinced that not all tire makers aspect ratios are the same, and clearly their side wall profiles/angles can differ. I had two sets of wheels on my 94 esprit...same wheel specs and offset, same tire specs but different makers. One set rubbed on full lock and the other did not. Only thing that changed in the equation was the tire make.
  20. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    What brand tires are on your car?
    I am running Bridgestone S04. It has very good review. I feel the tires are heavier and wider then my old Michelle Pilot Sport.
  21. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    They are Khumos something.
  22. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I also notice tire pressure makes some difference. When I set tire pressure at 35, it rubs fender a bit going over bumps at freeway speed, if I set tire pressure to 30, it seems not rubbing anymore.
  23. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    No, that's what I am using.
    Kai
  24. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Just had the 225 40 front and 275 35 rears put on today. Front looks much better... rears I'm thinking when these wear.. I'm going with 295.
    Mobilized reply by Dahveedem
  25. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    If your wheels are machined down, then you could try 285/35 or 295/35. If your wheels are not machined (like mine), then 275/35 with 30 psi tire pressure is the best choice. No rubbing issues so far. Personally, I don't see much difference between 275 and 295 if you look from distance away.
