Tire Valve Stems | FerrariChat
Tire Valve Stems
Discussion in '206/246' started by 4CamGT, Sep 6, 2025.
  1. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    On my Dino (03932) it seems all 5 valve stems are original. Four are Michelin “1342” and one is Michelin “1446”. They look identical except the printing on the inside. I’d love to know what valve stems are on other Dinos around my chassis #. My spare always had a slow leak and I suspect it could have been a leaky valve stem. Since I’m install new XWX’s I want to fix the potentially leaky valve stem. Before I take it apart, are the O-Rings available? What spec are they and where is a good source? Also..any other tricks sealing the valve stem?
    NoGoSlow likes this.
  2. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
  3. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,499
    Germany
    Matthias
    1352 are the original ones...
  4. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    Thanks Matthias. My next step is matching the original paint on my wheels (backside). Have you found what the original color silver is?
  5. GermanDino
    Aug 14, 2007
    3,499
    Germany
    Matthias
    no, as far as I know no colour sample exsits world wide for the rims...
  6. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    Wow! That’s amazing! I’m going to take one of my wheels and see if a spectrophotometer can help in color matching it.
  7. TTR
    TTR F1 Veteran
    6,031
    Riverside, CA
    Timo
    ... and as far as I know, perhaps like Daytona Cromodoras, no "OEM standard formula" never has existed or at least not publicized.
    Also why if one goes to an event/gathering/show which may have several 275s, Daytonas or Dinos present and looks (closely) at Campagnolos or Cromodoras on all of them, each car will more than likely feature different color hues of silver on their set of wheels unless painted by the same painter/shop using the same color match or formula they came up with.
  8. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    This is from a past post I found on F-Chat:
    https://www.ferrarichat.com/forum/threads/correct-cromadora-wheel-colour.552078/
    For the Carbureted wheel, the FERRARI TECHNICAL ASSISTANCE info N°182 say:
    Ref./Cromodora Magnesium Wheel Rims
    When a respray of magnesium wheels is required, the products to be used are the following:
    - Acrylic metallized paint - gray 2427078
    (smalto metallizzato acrilico grigio ghisa 2427078)
    [ed: literal translation is metallic cast iron gray acrylic enamel]
    which can be ordered directly to:
    - ITALVAR - Via Privata Bolla, 27 - Milano (Italy)
    The paint should be applied with viscosity 37" (Ford type viscosity meter - orifice 3), and baked at 212°F (100°C) for 40 min. in the over or under stoving lamps.
    Then, from 1982 to 2007, Glasurit shows that the code is Fer101 / Fer101c Argento Nurburgring.
  9. TTR
    TTR F1 Veteran
    6,031
    Riverside, CA
    Timo
    #9 TTR, Sep 8, 2025
    Thank you, I stand corrected, but I'm not sure the Glasurit formula is correct/exact match to OEM silver I've seen on Cromodoras ...
    OTOH, I wouldn't mind to be proven wrong.
    P.S. I have painted several sets of Cromodoras over the past couple of decades and experimented with variety of suggested modern formulas, but yet to find one as close match as I developed myself few years ago.
    Not saying it's a perfect(?), but much closer than most I've seen.
  10. GermanDino
    Aug 14, 2007
    3,499
    Germany
    Matthias
    unfortuately that doesn`t really help.... tried years ago....
    but gray is the key word... colour is for sure more grey than bright silver....
    TTR likes this.
  11. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    I went to my go-to automotive paint store. We got a close match with a swatch. They’re making me a spray can with a single stage paint. The original back of my rim has super small flake.
  12. TTR
    TTR F1 Veteran
    6,031
    Riverside, CA
    Timo
    Perhaps it's just the image quality, but this wheel appears to have two different colors/tones of gray-silver ?
  13. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    It’s all one shade. What you’re seeing is the shadow.
  14. TTR
    TTR F1 Veteran
    6,031
    Riverside, CA
    Timo
    o_O :confused:
  15. GermanDino
    Aug 14, 2007
    3,499
    Germany
    Matthias
    yes, they look ok.... but aluminium isn`t Concours correct nor the plastic caps... (will be a deduction)
  16. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
    I won’t be concouring my Dino anytime soon! The originals will be safely packed away. For me, the decision was safety and reliability with an accurate look.
  17. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,830
    Southern California
  18. HMB-Dino
    HMB-Dino Formula 3
    2,338
    Pebble Beach, CA
    RonG
    Don't forget the correct stickers for the back...which no one will ever see.
