Tired of filling/checking tire presures. | FerrariChat
Discussion in 'Technical Q&A' started by staatsof, Jan 3, 2024.
  1. staatsof
    95,935
    Fuggetaboutitland
    Bob
    So I no longer have a garage for my vehicles where I live most of the time. But I have 3 vehicles which I need to check. One has TPMS on it and it started warning the other day. A week later I got to checking it. The tires are 4 years old and high quality. The tires were all close to 28 lbs and are supposed to be 34. So I got out my compressor, long & higher pressure tire gauge that I use for the big 454 SUV with trailoring tires on it and my standard extended length filler. The damn connectors either wouldn't seal completely or they just block all air being pumped in. It was and extended PITA for someone who doesn't squat all anymore. My mechanics stool with casters did help and when I got done the warning light wouldn't turn off. :mad: The next morning it was still on :mad: :mad: But I was pretty sure it was at least close enough so I let my wife take out the car. Later on the warning light went away.
    But I'd like to makes this a lot easier so I looked for a tool that would:
    1. Reliably lock on and seal to the valve stem plus come off easily so that very little pressure is lost and also hook up with my air compressor that plugs in the wall.
    2. Allow me to set the fill pressure preferably with a quality digital gauge that can be easily read.
    3. Not be some cheap POS that gets any bad reviews.
    So ... is there such a beast?
  2. Steve Magnusson
    26,772
    You might check your OM as your car may do this intentionally (my Honda Fit needs like 20 miles of driving after correcting the tire air pressure before it turns the warning light off).
  3. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,955
    Southlake, TX
    Rob Lay
    Interesting concept a "trickle charger" for the tires.
    I can see how maintaining tire pressures can be a pain in the ass for most and I know most don't maintain proper pressures or check enough.
    I don't like to overthink it, but developed good habits as a racer where you check a dozen times a day.
    • buy a quality accurate racer type gauge with easy air release like the Intercomp 360067, only $60.
    • buy a quality power inflator that you can set the turn off pressure. I turn it on and go back inside to work on other stuff.
    • eyeball your tires EVERY time you drive.
    • if not driving for awhile, then over inflate the tires.
    • after every service, once a month, after a big temp change, or before a bigger trip check your pressures.
    • don't rely on the TPMS except to give you a heads up about a leaking tire.
  4. Snapshift
    Snapshift Formula Junior
    923
    Centralia IL
    Lyle D. Pahnke
    I'd get a locking inflator coupling. I use this one. https://locknlube.com/products/locknflate-locking-air-chuck?variant=39523505176660
    There are several variations of these available. Amazon or Google is your friend.
    I bought an Airmoto for my daughter and it has a screw on schrader valve fitting and shuts off at desired pressure. Still have to squat to screw it on where the lock on type are spring loaded and have an internally threaded jaw to lock onto the schrader valve.
    staatsof likes this.
  5. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Keep it simple. I'm used to checking the tire pressures my 5 vehicles about once per month (none have TMPS), checking with a good quality gauge and topping off as necessary with my compressor. Lately a friend turned me on to the Riyobi hand held tire inflator (about $170. through Amazon, including g 18V battery pack and charger). It's fast, easy, and the integral pressure gauge is dead-on when checked with a manual gauge. Doubt I'll ever fire up the compressor for tires ever again.
    Rexcat458 likes this.
  6. Isn't that what your butler is for?
  7. staatsof
    95,935
    Fuggetaboutitland
    Bob
    Sight ...
    Rob I to used track a race car and I already know all of this. I do as much as I can and I'm acutely aware of the condition of my cars but on a low profile tire eyeballing 6 lbs with certainty is tough to do.
    I need something that makes the job a lot easier now.
    Re-read my post. I'm no longer 50 or even 60, I have very little space.
    The quality and reliability of the tools being able to seal is what exacerbated the situation.
    I'm also operating in an extreme urban environment so tires get a LOT physical abuse. Cars in general get the crap beat out of them here which I suppose is why these tires lost air like they did?
    Think lots of potholes, curbs bumped etc.
    The sentence I highlighted is the key thing I'm looking for but I want a quality product. I always look at the worst reviews and if the complaint sounds educated and legit I pay attention.
    Amazon left me wanting so I decided to see if anyone here could point to a good unit from personal experience.
  8. staatsof
    95,935
    Fuggetaboutitland
    Bob
    Thanks this is part of the solution I'm looking for.
    The Airmoto looks like a bad choice for me though.
    The Chuck looks great. How easily does it disengage and what about leakage when it does?
  9. staatsof
    95,935
    Fuggetaboutitland
    Bob
    I'll have a look thanks.
  10. staatsof
    95,935
    Fuggetaboutitland
    Bob
    Well this looks like the complete solution: https://locknlube.com/collections/air-inflators/products/pre-set-digital-tire-inflator-gauge
  11. NYC Fred
    NYC Fred F1 World Champ
    16,062
    Fort Lauderdale, FL
    Fred C
  12. RedNeck
    RedNeck F1 World Champ
    12,253
    The CSA
    Me
    I have one of these. Works fantastic. I almost never even start my air compressor unless it's for air tools. Battery powered, portable.
  13. staatsof
    95,935
    Fuggetaboutitland
    Bob
    Or maybe just find a good tire shop and let them check periodically. But around here that'll be at least $75.
  14. staatsof
    95,935
    Fuggetaboutitland
    Bob
  15. rob lay
    Dec 1, 2000
    63,955
    Southlake, TX
    Rob Lay
    Yes, the low profile tires are harder to eyeball.
    I'm just not sure much can be done EVERY time if not willing to pressure the tires EVERY time. That's why I was just suggesting doing it periodically and you can depend on TPMS if you have a leak.
  16. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    Mystery TPMS light can sometimes be the spare.
  17. staatsof
    95,935
    Fuggetaboutitland
    Bob
    This looks like the most reasonable and rugged tool, requires a compressor which I'm OK with. I think it would outlast me unlike some of the battery operated ones I've seen and this would be quick!
  18. Snapshift
    923
    Centralia IL
    Lyle D. Pahnke
    instant disengage and no leak. I use it on a portable air carry tank with the lock on chuck attached to regular airhose. FWIW you can buy a 12V aircompressor setup at harbor freight and add the lockon chuck I noted. No need to spend 150 on such a setup but if you want the automatic stuff those tools look nice too.
    https://www.harborfreight.com/5-gallon-portable-air-tank-65594.html?_br_psugg_q=air+tank+portable
  19. staatsof
    95,935
    Fuggetaboutitland
    Bob
    So now I'm thinking about the hassle quotient involve.
    Right now I have to get a smaller compressor (not a pancake style, those are hopeless for this task). Yeah it's a lightweight HF 20 gallon one on wheels plus my smaller hose that's bright plastic POS one that's as stiff as a board when it's 40F outdoors, the tire gauge, inflator attachment that malfunctioned and small extension cord to plug into the small covered outdoor "foyer" outlet and get the hose unwound.
    This was a relatively big PITA and it shouldn't be. My three 50' rubber compressor hoses I have used for spray painting over the years is just overkill for this.
    So I'll be watching this video, the guy talks so fast he's damn near useless but he covers a lot of them.
    An annoying presentation isn't it. The guy needs to take a quaalude. ;)
    I'm thinking that there's probably one of these @ around $50 that will plug into my car's lighter outlet and top the tire up accurately pretty quickly. No extension cord, stiff hose or attachments to round up. I don't want one with a battery and charger and certainly no lithium ion fire starter. All my portable tools are NICAD. I want something that will last too. BTW both of my HF small compressors have been great. My Coleman 50 gallon compressor that I got in 1985 is a two piston model and is still OK. I just had to replace the tank once, my fault. I expect this tool to last me the rest of my life. I don't have that long. Ten 15 years tops.
    I really like the elegance of the one I posted in my previous post but it wouldn't alleviate all of hassle like this will. We shall see ...
  20. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,651
    Palo Alto,CA,USA
    Walt Kimball
    Based on a test by a Corvette publication,I bought a $79 Airmoto. It greatly simplifies my monthly pressure checks. To avoid squatting,I kneel using knee pads from the hardware store (I have been using McGuire-Nicholas for years).
  21. staatsof
    95,935
    Fuggetaboutitland
    Bob
  22. INRange
    INRange F1 World Champ
    12,527
    Virginia/Florida/Caymans
    JD
    At your age .....just get one of these to check them for you. I'm sure she would be willing to stop by once a week to make sure everything is properly inflated......;)
    hessank likes this.
