Tires for 355 | FerrariChat
Tires for 355
Discussion in '348/355' started by husky, Mar 1, 2005.
  1. husky
    husky Karting
    Feb 13, 2005
    136
    Hong Kong
    Patrick
    i am about to change my tires, the guy at the shop suggested P zero corsa 225/40/18 front and 295/35/18 rear but i am not sure!! 295 seems to be too wide cos standard size is only 265/40/18
    any suggestions?? thanks.....
  2. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    Husky,
    I think all of us have asked this question when we are due for new rubber on the 355.
    Take a look at this link and I think it will give you more than you ever wanted or need to know about 355 tire sizes.
    http://ferrarichat.com/forum/showthread.php?t=35046&highlight=355+tires
    PS. To answer your question - yes 295/35/18 will work just fine...
    Rich
  3. husky
    husky Karting
    Feb 13, 2005
    136
    Hong Kong
    Patrick
    thanks Rich
    actually i just rang up the dealer he said that the only size that will fit a 355 is either 265/40 (standard size) or 295/35
    mmm.... so the next question is which tyre PS2 or Corsa....
  4. richard_wallace
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    I like the Corsa a lot... However I put on the Kumho (I have no idea if I spelled that right). I had the corsa's on before - someone mentioned that the Kumhos are great performers and would last a few k more miles (less soft/powdery). I think they were about the same cost if I remember correctly. Since I never tracked the car - I can't tell you which performs better - but on the street they felt exactly the same to me...
  5. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    I have a 348 spider that I'm running 235/40-18 fronts and 295/35-18 rears on 8's and 10's - your 355 I would think would be similar and I am pretty sure your rear wheels are 18x10. Works great. I put Bridgestone S-02's on mine mostly because I like the tread pattern....
    Cheers
    Kevin
  6. husky
    husky Karting
    Feb 13, 2005
    136
    Hong Kong
    Patrick
    i finally made up my mind, i decided to go for PS2 225/40/18 front and 295/35/18 rear
    i was thinking P zero corsa but it costs 50% more, so realisticly speaking PS2 is a better option
    thanks guys for all your comments......
