Tires for my TR | FerrariChat
Tires for my TR
Discussion in 'Rocky Mountain' started by colo348, Aug 11, 2005.
  1. colo348
    colo348 Karting
    Nov 1, 2003
    143
    Colorado
    Jim
    Hi Group:
    I have a '91 TR and need to replace the rear tires. From my records I think the rears are the original tires, the fronts were replaced 8K miles ago. The back tires are Goodyear Eagle 255/50 ZR 16. Does anyone have a source for these tires, since I've been looking here in the Littleton area w/o any luck. I guess I could switch all tires to Michelin, but after Indy I don't think so. If you have any ideas I'm all ears.
    Thanks,
    Jim
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I always buy tires from Discount tire, if they don't stock a tire size they can order it. The carry Goodyear. Great prices and selection. imo
    Steve
  3. PowerDNA
    PowerDNA Karting
    Sep 5, 2004
    61
    Green Bay, WI
    Andrew
    You can also try Coker Tire.
    http://www.cokertire.com/
    You may want to search the achieves; there used to be contact listed on FerrariChat from Coker.
  4. colo348
    colo348 Karting
    Nov 1, 2003
    143
    Colorado
    Jim
    Thanks you guys for the advise I'll check it out.
    Jim
  5. PowerDNA
    PowerDNA Karting
    Sep 5, 2004
    61
    Green Bay, WI
    Andrew
    BTW, I checked with Coker, but they do not currently carry GoodYears or that size. Sorry.
  6. robert biscan
    robert biscan F1 Veteran
    5,080
    Nashville and Palm b
    robert s biscan
    Rear tires only last about 5k miles or so. The rears were replaced before the fronts. Your 8k milage is good. I put goodyears on mine and I would stick to the original tire if it is availabel. The tire characteristics may change your ride if you switch. It may be worth it to pay more to get them. Especially if you don't want to replace all 4.
  7. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    I think you'll find that the Dunlop SP8000 is about the best performance tire that manufactures a matching set of front and rears for the TR. The rears at 255/50/16 and with a 10 inch rim is an odd combo in this day and age. If you want a matching set and look at rated specs the SP8000 is about the only performance choice. Most other 255/50's aren't rated for a 10 inch rim.
  8. Roland E Linder
    Roland E Linder Formula 3
    Nov 3, 2003
    1,814
    COLORADO
    Roland E Linder
    Why don't you step up to 17" and have a much better choice in tires.
    I did it for my 91 TR with the new RONAL rims and beside the look changes I have better tires and a better handling car.
    Roland
    F40LM
