tires | FerrariChat
tires
Discussion in '365 GT4 2+2/400/412' started by bundas, May 5, 2014.
  1. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    1977 40 needs tires, V rated would be best but lower rate is OK all weather is my choice. cannot source, help
  2. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    Not hard to findm but potentially pricey.
    Original size is 215 / 70 VR 15
    You can get correct V rated Michelins from Longstone Tyres in the UK ( sponsor of Fchat) or something else here:
    Tirerack
    M
  3. Ak Jim
    Ak Jim F1 Veteran
    9,625
    North Pole AK
    What size is on there now? I have Pirelli P4000 in size 215 70 R15 which are speed rated but are no longer being made. There are other speed rated tires available but they are a slightly different size, sorry but don't remember all of the details. I'm thinking of getting these tires in 225 70 R15 and mounting the raised white letters facing in, I have done this on another car I have and have used these tires for the last 3 sets of tires I have put on it (car has 205000 miles) and am quite happy with their performance.
    BFGoodrich Radial T/A
    Good luck, you can always call tire rack, I've always had good luck with them.
  4. rovexienus
    rovexienus Formula Junior
    588
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    Hello,
    Vredestein (Home - Vredestein) has a series of 215/70 for 15" rims, one of them is called "Sprint Classic", speed rated "W" (up to 270km/h), cheaper than Michelin in Europe.
  5. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    uses 255x60rx15. Pirelli scorpio V rated that tire was used on a 1980 Vette
  6. Ak Jim
    Ak Jim F1 Veteran
    9,625
    North Pole AK
    255 might be too wide for a 7.5" rim.
  7. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  8. Nathan76
    Nathan76 Formula Junior
    Jun 20, 2013
    344
    Leicestershire, UK
    So if you can get yokohama for 81 dollars a corner why are people spending so much on the pirellis? ?
  9. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Italian shoes!
  10. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    I've got BFG 225/60/15s and they work outstandingly well. They're only 1 inch shorter, so that works out to only 1/2 inch lower an the tracking and handling is much superior. Less sidewall sway. Jq.
  11. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    2,024
    Dougal
    Sorry but i don't think tires should be bought just on price. Can i encourage you to buy the tyres that will make your car handle and look the way they should. 215 / 70 VR 15 Michelin XWX
  12. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    The pickings in 15" are getting slim, not many decent ones. BFG makes a 245/60 x 15" which is only 6mm shorter than the originally fitted XWX.
  13. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    uses non metric I want a V rated tie as I drive 100-125 all the time
  14. Ak Jim
    Ak Jim F1 Veteran
    9,625
    North Pole AK
    Watch out for the police, I'd hate to have to post your bail! :)
  15. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    Just in passing...I have been running BFG 225/60/15s on my 1980 and love them. However, when purchasing new tires, I originally had preferred to get 245's like I had seen on a 400 in L.A. years back. Upon finally fitting the 225s,
    I found that (on my car, at least), that the 225's fit the wheel wells perfectly, but left only 1/2"-3/4" clearance between the sidewall and the inner edge of the wheel well, leaving me totally relieved that I had not gone for anything wider. And they look just as "cool", if not better that the wider tire. I love my BFGs, and would also consider the Vrendesteins that I have fitted on my 'Vette. I love them way more than the previous Pirellis. I hope that this is of some help to someone. Thank you. Jq.
  16. Ak Jim
    Ak Jim F1 Veteran
    9,625
    North Pole AK
    What BFG is it?
  17. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    +1!
    Excellent :)
    All the time :D
  18. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,024
    Dougal
    Michelin have presently run out of the 215/70VR15 XWX. I still have some 215/70VR15 Michelin XWX
    There will be a new production in the near future.
  19. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Just got 6 points; 12 and I am out for 2 years. Had been running 90 plus all the time. Will have to change. Will b awhile until I drive again. Just out of ICU. FELL hard. In rehab. Now
  20. DaveO_48
    DaveO_48 Karting
    Jul 29, 2013
    184
    Henderson, Nv
    David Odland
    Mitch,
    You need a "track day". Then you won't get so aggressive with the blinking weeds! Aren't there any road course outings put on by Ferrari Clubs in US?
  21. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    But I am too old. Did my last track event in 05 at tie FCA Indy. Meet. 165 in the turns (550) was more than I needed. 20 min. Session was enough. I went home. Interstate with no one on the road is stressful enough at 125.
