Titanium wheel bolts tight to fit? | FerrariChat
Discussion in '458 Italia/488/F8' started by DavidYu888, Apr 2, 2025.
  1. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    I bought a set of new OEM genuine Ferrari titanium wheel bolts, but when the tech tried to fit them, they "bind" after half a turn and won't go any further in just using your fingers.
    I specifically didn't want them to use a wheel gun, but they are mystified as to why the bolts won't simply screw in like the stock steel ones.
    The specs say they are identical and apparently haven't changed across all models for many years, but one mechanic reckons the pitch of the thread looks steeper on the titanium ones, which would explain why they bind.
    Has anyone else encountered this or can offer an explanation?
  2. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    628
    Trevor H
    From what you say I can't think of any explanation other than they are the incorrect thread.
  3. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    That shouldn’t be possible, but yes I guess so.
  4. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,088
    Todd
    Not OEM.
    mdrums likes this.
  5. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Measure diameter of threaded part and compare each bolt. Use a micrometer. Also a thread pitch gauge for metric thread. Probably not OEM and threaded diameter too large on major thread diameter. A good machine shop may be able to rethread the titanium ones to match the OEM threads.
  6. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    So I took the bolt I bought to our local Ferrari dealer parts department where the guy was incredibly helpful.
    He let me see the correct bolt, (part number 206274 if you're interested) and it had a VERY slightly finer thread pitch, i.e. the threads were slightly closer together than the ones on my bolts.
    Test fitted one and it fitted perfectly as expected (can't quite hand tighten without using a socket, but no serious resistance).
    He is trying to find out what other Ferrari titanium bolts there are, as he did think mine looked OEM.
  7. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,482
    Tampa FL
    Your wheels bolts should be M14x1.5x75mm equivalent to Ferrari part 000247702 and fits most Ferraris including the Ferrari 360, 430, 458, 488, 612, 599, F8, 812, 296 GTB, Roma, California Portofino and other Ferrari's. 75mm is the overall length and the shaft length is 52mm (length under the base of the cone until the end of the threads) for the standard length assuming you are using original wheels and have not added spacers.
  8. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    Interesting, that is not the part number that fitted my car, it was definitely the 206274. We test fitted them.
    Still don't know the part number of the ones I bought that definitely do NOT fit the F8.
  9. Dominik B.
    Dominik B. Karting
    Mar 5, 2017
    187
    Cape Town/Frankfurt
    Dominik B
    M14 bolts come in:
    M14x2mm (standard machine thread, DIN 13). Not that M14 is an usual thread in engineering to start with.
    And fine threads:
    M14x1.75mm
    M14x1.5mm
    M14x1.25mm
    This can be confusing.
    You cannot change the pitch by treading one pitch over the other. You ruin the bolt
  10. JoeCab
    JoeCab Formula Junior
    443
    Colorado
    Joe C
    The difference between these thread pitches should be very obvious to the naked eye. Rather than being the wrong thread pitch, I would suspect the threads are simply cut incorrectly or have some schwarf that is making them bind.
    Can you try cleaning up the threads with a 1.5 pitch thread file? This would take care of a small inconsistency as well as any machining issues that could cause the binding?
  11. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    It’s a subtle but distinct difference in pitch. The one I bought is on the right, the correct one for an F8 (and many other models) is on the left. Waiting to hear which models the one I bought fit.
  12. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,482
    Tampa FL
    David I can verify that the threads for Ferrari 458 488 and F8 are the exact same. I had a 488 and then my current F8. I played around with putting my HRE wheels I used on my 488 on my F8 using the same bolts for both cars with no issue. I then sold these wheels and bolts to a 458 owner and we put them on his 458 with no issue.
    You need to exchange the wheel bolts you received for ones with the correct thread pitch ...M14x1.5mm bolt length will depend on if you have OEM wheels or aftermarket wheels and have changed offset spec.
    DavidYu888 likes this.
  13. Dominik B.
    Dominik B. Karting
    Mar 5, 2017
    187
    Cape Town/Frankfurt
    Dominik B
    Looking at the pic, I am tempted to say it's the same pitch (hold them into each other), but your bolts look bad. Like Joe from Colorado assumes, too.
    Try a thread file, or better a M14x1.5mm die. However, I would return them.
    mdrums likes this.
  14. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,928
    France
    #14 LVP488, Apr 5, 2025
    206274 is the titanium bolt listed on the Pista parts diagram - so that's definitely right.
    247702 seems to be a superseded (replaced by 70006039) regular (not titanium) bolt part number.
    For whatever reason, 70006039 is applicable to a certain 488 GTB assembly number, and then a 803384 is applicable.
    The 206274 is listed for the 458 Speciale but the 458 Italia (which has the 247702 and 70006039, and no 803384, as regular bolts) has a part # 70004715 for titanium bolts.
  15. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,482
    Tampa FL
    I agree.... now that I am home and using a large high end monitor the threads on the bolt that is getting stuck look bad.
  16. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    Thanks, I will see if the parts guy from the dealer has this on his system. Very strange that the 458 Italia alone had a different titanium thread pitch. Surely the steel bolts for that model would also have the same unique pitch?
    I would just like to know so I can resell them for the right car.
  17. todd cloud
    Jun 21, 2019
    1,088
    Todd
    Not OEM.
    mdrums likes this.
  18. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,482
    Tampa FL
    I can guarantee you that the 458 and 488 F8 are the same thread pitch. I’ve put my wheels from my 488 on F8 and 458 with same bolts.
  19. ferrefeh
    ferrefeh Karting
    184
    Illinois
    Feh H
    The finish on the material on the left looks different for sure, that's how mine look exactly (smooth titanium). Do they weigh the same?
  20. d16dcoe45
    d16dcoe45 Rookie
    Aug 4, 2024
    13
    Tarrytown NY
    Jay Justin Lestingi
    #20 d16dcoe45, May 20, 2025
    Stock F8 bolts are M14 - 1.5mm x 77mm
    Have you verified OD and thread pitch? I run titanium wheel bolts and studs on my cars and never ran into an issue. They pretty much all come from the same place no matter whose name is on them.
    Get a metric thread pitch gauge on Amazon if you don't have one and a set of digital calipers.
    Most wheel bolts for all manufacturers are going to be M12 or M14 with a thread pitch of 1.25 or 1.5mm. Sometimes you will run across 1.75mm and as was stated, you can't rethread the bolt on a something that had to hold a wheel on a car. You have to measure and start with the correct size bolt.
  21. DavidYu888
    DavidYu888 Karting
    Nov 7, 2024
    96
    David Yu
    So I ended up buying another set that fit the F8 (also confusingly listed as 206274!) and they've gone on fine.
    Yesterday I test fitted one of the first set I bought on a friend's F430 and that fitted perfectly!
    So the first set I've got definitely fits the F430 and according to Maranello Classics, a rather eclectic mix of other models including the 360 CS (but not regular 360), 599 GTO (but not regular 599) and this is what is really freaky, 458 Speciale and 488 Pista, but not regular 488 and definitely not F8!
    https://www.ferrariparts.co.uk/part/ferrari/206274?id=127767
    So basically the parts listings cannot be trusted and Ferrari definitely did change pitch thread somewhere between F430 and F8. This set are 1.5mm according to my friend's pitch gauge.
    Anyway, I guess I should advertise the spare set in the F430 section! :D
