To belt or not to belt .. that is the question | Page 2 | FerrariChat
Discussion in '308/328' started by robbie, Jul 23, 2017.
  1. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    +1 Whenever I mention a belt change, I assume it includes the tensioners by default. It'd be crazy to go to the trouble of changing belts without swapping out the tensioners, too. They usually come together as a kit anyhow.
  2. mwr4440
    58,120
    Bavaria, The 'Other' Germany
    Mark W.R.
    Whatever you choose, best of luck in the sale. :)
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,679
    San Carlos, CA
    Mitchell Le
    I have a lot of experience with 328. If I were selling this car, I would do this:
    1. Change the belts
    2. Put on Hill Engineering bearings
    3. Measure valve clearance and record them to be in spec, and replace the valve cover gaskets
    4. Change or rebuild the 29 years old water pump
    5. Change the two fuel connecting hoses at the bottom of the tank
    6. Splice in a 12 inch section of the heater hose
    7. Change the two coolant hoses at the back side of the water pump
    And call that a very good major service. Anyone else demanding other things to be changed can do those other things AFTER they buy the car, or tell them to buy another car.
  4. Dr Tommy Cosgrove
    36,614
    Birmingham, AL
    Tommy
    I would do #1 and #2 and tell them to hop on #4 - #7 when they get it home.
  5. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    1 & 2 only (and only then if its more than 3 years since they were done) + V belts & a fluid change. If the valves were done (3) inside the last 10K miles I wouldn't even think about touching them. If the WP isn't leaking (4) & it feels alright then leave well alone. If the tires are over 5 years old change them, same for the pads if more than 50% worn
    The rest is restoration work for the new owner.
