To start or Not to start | FerrariChat
Discussion in '348/355' started by khcompt, Oct 21, 2015.
  1. khcompt
    khcompt Karting
    55
    Halifax, Canada
    Ken Compton
    I will be storing my 355 F1 for the winter (Edmonton Ab) and would appreciate some feed back on weather to start it up once a month and run it up to temp, or is it better to not start it at all. It will be in storage for +- 6 months
    Ken
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I would leave it. The cold starts you are talking about will be likely in minus 20 degree temps. They will likely do more harm than good. Start it in the spring when its been above zero for a while.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    Yes, leave it sit. If you can not get everything up to temperature starting it and letting it run for a short period is the worst thing you can do. Starting is one of the highest wear periods for any engine due to lack of oil pressure. Additionally, a cold engine generates a lot of liquid water in the exhaust which only serves to promote problems.
    Fill the tank with gas, disconnect the battery and forget it. Some will say add 5 psi to the tires to help prevent flat spots, though I have never done so.
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    button it up with proper storage procedure and then leave it alone!
  5. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    (1) Fresh gas
    (2) If you are more anal pump up the tires to about 50 PSI and put a post-it on the steering wheel to remind yourself to decrease the pressures before driving
    (3) Plug in battery tender (not a trickle charger)
    (4) Don't start the car again until ready to drive
    (5) count down the months to when you get to drive her again :)
