TODA TAKE Spec 355 rebuild | Page 3 | FerrariChat
Discussion in '348/355' started by Future ferrari collector, Sep 9, 2020.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,856
    Lake Villa IL
    "polishing up the existing ones" could mean as little as cleaning and re-assembling to any degree of porting for increased flow. I would guess based on your response it was a clean up/re-assemble.
    If you don't have access to a dyno with a wideband, in the meantime at least install a wideband a/f sensor and gauge in your car to confirm it's not too lean at WOT/High rpm.
    That's quite an investment into an engine, would be money well spent to confirm it's at least safe on the fuel side.
  2. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,013
    would like to write an eloquent comment about this, but i only have one word
    D R O O L
    Bas likes this.
  3. Callum Davis
    Callum Davis Rookie
    Sep 23, 2018
    6
    United Kingdom
    Callum Davis
    Hi there,
    Great build!
    Would love to see a video of this engine running, how far off are you from having the car in a usable condition?
    Callum
  4. Callum Davis
    Callum Davis Rookie
    Sep 23, 2018
    6
    United Kingdom
    Callum Davis
    Been thinking of using TODA to upgrade my F355 engine but have not found any videos of how the engine runs, would be great if there are some out there.
    Worried its to 'racer' for regular use.
  5. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    @INTMD8 If someone just ran their cams, would the stock ecu suffice?
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,856
    Lake Villa IL
    Stock ecu's with stock programming? I don't think they would. Even with stock cams a higher rev limit would be beneficial. Would need to be completely remapped in order to take advantage of different cams, IMO.
  7. ShineKen
    20,202
    Southern California
    Nostradamus
    Do you have a 2.7 or 5.2? I can link some vids here later.
  8. ShineKen
    20,202
    Southern California
    Nostradamus
  9. ShineKen
    20,202
    Southern California
    Nostradamus
    He's got quite a bit of mods including light-weight front and rear bumpers, brakes, suspension, aero. Running Toda 4-1 headers. He's done alot to make it similar to challenge car spec. He does about 2:26-27 on Suzuka Circuit. I've seen a 355 challenge car with just an Ito muffler and re-valved Bilsteins do 2:25. Bottom line... start with a 2.7 car :).
  10. Future ferrari collector
    Oct 12, 2006
    1,795
    Hi guys,
    Not checked in for a while. Engine has been broken in, serviced and went for a re-map of the ECU to optimise timing, fuel mixture.
    So now she runs on 98RON, 93 Octane to you guys in the US, rather than 100RON/96 Octane as she came from TODA.
    Note that the dyno graph was from a Mustang dyno, supposedly more conservative on the HP numbers.
    Ran her up to 7.8k rpm with pleasing results, peak power is at 8.5k in current spec so TODA's numbers based on a race fuel, TODA exhaust set-up, giving 450hp is very believable.
    Numbers aside, the increase in torque throughout the range plus the much more urgent pull pass 5-6k are extremely noticeable vs the old engine. Car is very tractable, what I used to do in a particular gear, I now can do the same or better in one gear higher.
    Attached are the dyno numbers for those keen. Again, been busy running around to sort the car out so apologies for the PMs which will now be answer.
  11. Future ferrari collector
    Oct 12, 2006
    1,795
    To clear up any doubts, the Unichip rides piggyback on each individual Motronic ECU.
    The factory injectors are more than sufficient for this current set-up. Basically it was tuned till Best Lean Mixture then advanced till knock detected before retarding back 2 degrees on the timing. Works well.
    Fuel consumption is now approx 15-20% more
  12. Future ferrari collector
    Oct 12, 2006
    1,795
    It is perfectly usable on the streets. If anything, its more tractable now with the higher torque esp at the lower end which wasn't a 355 strong point. When you floor it while rolling along at say 5k, the only you might feel is the scrabbling for grip on the rears. I run PS4s 275s rather than the std 265. Sound wise, it is still recognizable 355, just a tad louder, deeper but the pitch/wail is the same.
    Senshi458 likes this.
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,856
    Lake Villa IL
    Nice you were able to calibrate it on a dyno. Why cut the pulls early? I'm surprised at the amount of torque you picked up. Not sure how they arrived at 25% drivetrain loss.
  14. Carmellini
    Jul 16, 2019
    1,013
  15. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,147
    Josh @jtcarprojects
    Toda was always amazing stuff in my honda days. Would love to have there engine in my 360
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    I'd like to talk to you about your cars warranty :)
    IvanRico and Carmellini like this.
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I like it
  18. Senshi458
    Senshi458 Formula Junior
    Sponsor Owner Rossa Subscribed
    Oct 17, 2015
    933
    Norway
    Reza
    Any updates from the OP, would love to do Toda stage 1 on my car
  19. philo
    philo Rookie
    Jul 17, 2005
    34
    sound clip anywhere?
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Any more details on the Unichip setup?
  21. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,473
    Los Angeles
    No alternator?
  22. fatbillybob
    Aug 10, 2002
    29,464
    socal
  23. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    Though not the OPs car, this one has TODA cams...
  24. ShineKen
    20,202
    Southern California
    Nostradamus
    My understanding is this car is equipped with a full Toda engine build.
