TODA TAKE Spec 355 rebuild | Page 4 | FerrariChat
Discussion in '348/355' started by Future ferrari collector, Sep 9, 2020.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,080
    Southern California
    Nostradamus
  2. ShineKen
    20,080
    Southern California
    Nostradamus
    This car has a Take spec build.
  3. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    When using those extended runners, what covers/filters are used, if any?
  4. ShineKen
    20,080
    Southern California
    Nostradamus
    This guy most likely just used filters, but I haven’t seen the update.
    I am in communication with one of the gentlemen in Japan with the Matsu-spec build. There’s only a handful of owners who’ve made the plunge.
    For most of us. Take spec would be most ideal.
    If I ever do go this route, I would visit Toda’s facility personally to make sure I understand the whole process. I have a Motec tuner here. @INTMD8 is also a great tuner and engine builder. I bet he can put together the Toda engine (if supplied a kit) as well as tune it.
    SteveRielly likes this.
  5. ShineKen
    20,080
    Southern California
    Nostradamus
  6. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    The build I'm planning, which has yet to start with the actual car purchase, is definitely with the Matsu spec engine.
    It will be a mix of track and street, even it's a bit growly with 'normal' driving.
    ShineKen likes this.
  7. ShineKen
    20,080
    Southern California
    Nostradamus
    What fuel would you be running on the street with a Matsu spec?
  8. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    I'm based in New Zealand, so we have 98 at the pump.
    In saying that, I'm thinking I'll most likely have this car based in Europe so that during the New Zealand winter I'll head up there for summer track days,
    and from what I've been told there is fuel at the pumps to cater for such an engine.
  9. ShineKen
    20,080
    Southern California
    Nostradamus
    Well if you haven’t already bought the car, my advice would be to look for a 2.7. Both Rosso Corsa cars mention above are actually 5.2 cars and not real challenge cars.
  10. ShineKen
    20,080
    Southern California
    Nostradamus
    https://rmcmiami.com/inventory/1996-ferrari-f355-b-gated-6-speed-fully-documented-build-stoptech-bbk-toda-cams-recently-serviced/
    “Moving to the engine bay underneath the Gruppe M airbox and side panels you’ll find a fully tuned engine featuring a full TODA racing valve train and cams alongside high compression pistons, ported & polished heads, Accel direct ignition conversion, upgraded fuel injectors, ported intake manifold, all being controlled by a Motec M4 computer. To address cooling a pair of oversized radiators have been fitted along with a trick oil cooler. The end result of these modifications is a flat plane V8 that has the chop at idle of an american V8 but screams like the italian V8 it is at full throttle.”
    Only companies in Japan I know building high compression pistons for the 355 is Toda & Iding Power.
    OCKlasse likes this.
  11. ShineKen
    20,080
    Southern California
    Nostradamus
  12. ShineKen
    20,080
    Southern California
    Nostradamus
    96RON = 92 at the pump in U.S roughly.
    In California, highest we can conveniently get is 91, so we probably need to go 11.5:1 to be on the safe side. The lowest Toda has is 12.0:1.
  13. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    I was looking at that, but figuring that as I'm likely to be changing the ECU, the engine set-up etc, it may not matter that much which one to go for as a base.
    Much like getting an F1 as it's a cheaper base potentially, and put in a race peddle box....provenance is of no concern to me at all.
  14. ShineKen
    20,080
    Southern California
    Nostradamus
    There’s more to it than that.
  15. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    May be so, but why get a 2.7 over a 5.2?
  16. ShineKen
    20,080
    Southern California
    Nostradamus
    Air routes to the intakes differently on a 5.2. It is less effective than 2.7 in real world driving, hence owner of this 5.2 Toda car had to go this route. *I still don’t think it results better than 2.7 cold air route to the boxes.
    Second reason is 2.7 comes with bigger injectors good up to 450 hp @ roughly 90-95% duty cycle. My bet is “385 Challenge” isn’t making the full 450hp with 5.2’s smaller injectors and also getting less cold air in real world. The Toda 5.2 Berlinetta with challenge-like suspension and weight reduction mods is just about as fast as a stock 2.7 355 challenge (with cats still in place) on Suzuka Circuit.
    If going Matsu, one would need upgraded injectors. I haven’t seen reports of reliable upgraded injectors made for the 355. The RMCMiami car had upgraded injectors… but it also had tuning issues. I was contacted to help find a tuner. Probably the reason the owner in Japan sold it so quickly after he had just built it. This is all speculation on my part, but my hunches tend to be close to reality :).
    At this stage, it seems like starting off with 2.7 is a safer bet. If you’re going all out Matsu spec, you will need to find reliable upgraded injectors and hopefully it can be tuned smoothly as well.
  17. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    Toda should be able to give direction on the injectors, as I would have thought if the OEM injectors were not up to the task,
    they would supply the ones they recommend with the kit.
    Having those filter socks on the trumpets doesn't look like a good fix at all, you would have all sorts of heat-soak issues.
  18. ShineKen
    20,080
    Southern California
    Nostradamus
    Details of their kit is posted on their site. Injectors are not included. OE Injectors are up to task up to Take Spec if you have OE 2.7 injectors.
    I would send them an email to inquire.
  19. d16dcoe45
    d16dcoe45 Rookie
    Aug 4, 2024
    23
    Tarrytown NY
    Jay Justin Lestingi
    Toda was always known as one of the highest quality Honda builders. They were one of the first companies to make a dedicated camshaft that eliminated the low rpm VTEC mechanism. It would run a large cam at all times because in racing, the low rpm cam was of course not necessary.
  20. ShineKen
    20,080
    Southern California
    Nostradamus
    The more I think about it, the more I think 12.0:1 CR might be too aggressive for our pump fuel. 11.5:1 is probably a better bet. Those would need to come from Iding Power.
  21. OCKlasse
    OCKlasse Formula Junior
    711
    Newport Beach, CA
    Brandon K
    From what I heard, an injector was bad. Replaced and now running well :)
  22. OCKlasse
    711
    Newport Beach, CA
    Brandon K
    We have 100 readily available in Newport :)
  23. SteveRielly
    SteveRielly Rookie
    Aug 19, 2024
    44
    Steve Rielly
    I have two motorbikes that run 13+ CR on our Pump BP98 with no issues.
  24. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,924
    Richmond
    Pete
    CR should be matched to the cam timing and fuel available, but the gains from 11.5 to 12:1 are extremely minimal so not worth any effort to do imo. Even in a flat out race engine, it's a couple HP at most.
