Todays first rollout after 5 Years :) | FerrariChat
Discussion in '348/355' started by Samy, Mar 30, 2010.
  1. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    #1 Samy, Mar 30, 2010
    Hello,
    today is the day after long 5 years i drove the car out of the garage by its own and finaly without any exploding , breaking parts right on the first meters :) Everything is sealed fine no leaks it even shifts smooth :) only some minor problems occured like the new stock clutch engaged only at the last mm of the pedal way. The brake pump starts to pump after only 2-3 steps on the brake pedal. And my electronic throttle valve engages a bit to slow on low rpm wich makes it easy to stall the engine if the clutch is engaged to quickly. But idle rpm is at nice happy 1500rpm :)
    But i'm just happy that this long project finally comes to an end. Next step is to get the first miles on the engine change the oil and put the pedal to the metal to setup the rest of the full throttle relevant mappings.
    And thanks to those in this forum who helped me bringing that project to where it is now. Especially my gearbox helpers :)
  2. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    Congrats man! Post more pics with it out in the sun!
  3. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,631
    VA
    Brendan
    #3 junglistluder, Mar 30, 2010
    awesome! what's the back story? why did it sit so long? Your clutch issues and idle don't sound good though....
    Oh yeah.... Those wheels are SICK!!! Incredible actually!
  4. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
  5. junglistluder
    Mar 23, 2007
    3,631
    VA
    Brendan
    Your brake issue doesn't sound too good either... possible ABS pump issue.
    What is the electronic throttle valve? is that the idle control valve? try removing it and cleaning it with some carb cleaner. it may be sticky inside.
  6. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    #6 Samy, Mar 30, 2010
    It took so long because i did an engine swap wich wasn't that easy to do. First my stock gearbox broke into pieces. Then the input shaft then my custom solid flywheel with AP racing 7,25" tripple disc clutch made problems. Also much problems to fit the engine to the gearbox and everything inside the engine bay.
    The idle is no problem its like it should be because of the used cam profil the idle wouldn't be stable enough in lower rpm so 1500 is fine :)
    The break pump sounds ok i think it maybe is a weak break pressure reservoir or however that thing is called in english.
    No my engine has a complete electornic throttle valve it has no idle contrl valve because the Ecu controls the idle by opening the throttle valve. But like i said it is supposed to be 1500rpm target idle so that is fine. Ok the neighbours starred at the car and yelled over "oh is it damaged it sounds so rough" :)
  7. junglistluder
    Mar 23, 2007
    3,631
    VA
    Brendan
    #7 junglistluder, Mar 30, 2010
    OH SNAP!!!! That's a 348!!!!!!!! :D
    EDIT: what kind of motor is in there?! C'mon.... give some details on this thing! Looks wild.
  8. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
  9. Argento839
    Oct 21, 2005
    9,103
    #9 Argento839, Mar 30, 2010
    +1 can't quite make out what the symbol is on his avatar.. definitely not a Ferrari powerplant..
  10. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Looks like the Opel symbol; circle with a stretched out Z, or small lightning bolt.
    Kai
  11. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    100 Points , that is correct :)
  12. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Whew! Good thing it's not actually a 355. :)
    But great work with all the upgrades. Will be interesting to see how well it goes.
  13. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    If the gearbox hold longer than last time it will go well ;) Ok i removed the week points of the gearbox and put the stock flywheel back i think positive that it will work now. If not hewland builds strong gearboxes wich will fit into the 348/355. That would be the last option. But it will work now ..... it must don't like the idea to spent more time on it without driving it sometime.
  14. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    What engine is that ?
  15. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    What wheels are those? What seats are those?
    Sooo many questions!
  16. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    Congrats, looks good and the wheels look fantastic
  17. Lars_vet
    Lars_vet Formula Junior
    Feb 25, 2007
    603
    On the open road
    Lars
    Amazing look! More pics please?
    What kind of wheels are those?
    What did you do to the rear panel? (where the stock 348 rear grill normaly is)
  18. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    #18 Samy, Mar 30, 2010
    The Wheels are Elias wheels or better known as Azev Type M 19" .
    The Seats are Sparco Rev Plus 7.2KG each.
    The engine is like already identified a opel/Vauxhall/Lotus one. Or at least the raw cylinderhead is. The rest is different and made by me.
    I converted the read panel to 355 look. I used a stock 355 rear panel and new light bulbs and fitted it to the 348 rear. The only 348 things i left on are the mirrors, the side skirts and the rear hood.
  19. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,186
    Huntsville, AL., USA
    Andrew
    Interesting project... I'm curious, why were you doing an engine swap? :)
    All the best,
    Andrew.
  20. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Congrats, Samy! Great job! Looking forward to the report after you wring it out!
  21. X11OUD
    X11OUD Formula Junior
    Mar 22, 2008
    729
    Manchester, England
    Neil
    Your car is looking great, looking at the ride height you obviously don't have speed bumps where you are!
    Interesting transplant, how much power will you have when running and mapped?
  22. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    That would be my question--why the engine swap. Does not make sense to me but I'm sure you had a reason. What kind of HP do you have & what is the weight saving of using different powertrain?
    What do you think your car is worth now?
  23. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    looks good
    more pics etc plz
  24. S-T48
    S-T48 Formula Junior
    576
    Stevenson Ranch, CA
    ++++11111111 please
  25. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Congrats to hear Sammy! :D:D
    Its been a long time coming! :D:D
    Looks ****en fantastic!! ;);)
    I, like many.............LOVE those wheels!! Please post more pics of the car when you can mate! :D:D
    Good luck with sorting the engine mapping out! At least all the hard work is done! Seeing it roll out of there is great!! :D:D
    Congrats again and enjoy my friend. :):)
