Toe question, very theoretical. | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Feb 25, 2017.
  1. 24000rpm
    24000rpm F1 Rookie
    ok, to revive this thread, since I have another car that I can compare to.
    I have a lincoln town car that is pulling to the right (steering wheel also to the right if you let it off)
    I have a 300zx that is also pulling to the right (steering wheel also to the right if you let it off)
    the difference is:
    if you put town car into neutral, on a flat surface, push the car forward, the steering wheel will go to the right. Push the car backwards, the steering wheel will still go to the right..
    if you put 300zx into neutral, on a flat surface, push the car forward, the steering wheel will go to the right. Push the car backwards, the steering wheel will go to left!
    My guess is the 300zx is having a rear wheel toe issue and the town car has a RH brake drag.
    I'll go to alignment and update the results.
