Too high of octane for 355?? | FerrariChat
Discussion in 'Technical Q&A' started by butch355, Feb 13, 2008.
  1. butch355
    butch355 Karting
    Jan 27, 2005
    114
    Denver
    Brent
    I found a gas station that sells higher octane gas near me and was wondering if anyone had any experience using so called "race gas" in the f cars?
    I have 97 355 and how little I drive it thought it might be worth it for the better gas. Also, in Denver our Octane is limited to 91 with 10% ethenol all fall and winter.
    Also, was is the highest octane we could run in the modern f cars. I have some older Porsches and was wondering about the same thing since I have the cars chipped to handle the 91+ octane.
    Last, would this just be a waste of money and risk of causing damage for whatever reason??
    Thanks,
    Brent in Denver ready for the snow to finally melt and be able to drive!!!!
  2. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Around these parts 91 isn't considered race gas, which in my exp anyway at track days is 100~110. Running that in your 355 won't hurt it but besides the nice fumes those behind you will enjoy it won't do much for you on the street, i.e. wasted money.
    Unless you don't mind spending more money than is necessary, you only need run the lowest octane your engine will burn w.out knocking. And that's usu the manfctr's recommended octane.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    Most stations around here have 93 at the pump for the super grade---That is what I use with never a problem....
  4. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Caution: Race gas is leaded fuel. You will destroy your emisions system if you run real race gas. That said you can get high octane unleaded fuel at certain places. I believe Sunoco has 93 octane and I have seen higher unleaded available at some of the tracks.
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1......... check the ingredients for lead.... ;) ............. otherwise super high octane will not hurt anything.... :D!!!
