too loud | FerrariChat
too loud
Discussion in '456/550/575' started by F612, May 8, 2019.
  1. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    I have tubi style mufflers on my 575 and it's too loud for me. Anybody have stock mufflers (rear) for sale or swap?
    Any other ideas?
    paulchua likes this.
  2. colamclean
    colamclean Formula Junior
    Nov 5, 2013
    306
    McLean, VA
    Patrick Transue
    David, I posted a similar thread weeks ago. I feel your pain. The previous owner of my 575M installed early 550 Tubis which are very loud and the drone inside the cabin in unbearable to me after 30 minutes or so. I suggest you first find out what Tubi exhausts you have. The 575 Tubis came in loud and ‘regular’ versions. I don’t know how the two are distinguished, but the 550 Tubis are stamped as 550s and they are very loud. I will exchange my 550 Tubi exhaust for the quieter 575 Tubi when I get around to it. Seems you can get used ones for about $2k. I am looking for someone to do a swap - most people seem to want the extra rumble of the loud exhausts.
    Spider68 likes this.
  3. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    My car makes almost no noise. I will rectify that situation in a few months :D.
    Daniel, Danke.
  4. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    771
    san jose, ca
    steve
    mine was the same and i put it back to stock and i like it.
    pilotoCS likes this.
  5. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    If you choose to put your car back to stock and be correct part number wise be advised there are several stock silencers divided between the 550, and early and late 575 versions. They all will bolt up and function properly. The later 575 version likely flows the best but not by much.
    Should you go out into the used market place to purchase be sure you are getting a matched pair. Each silencer has a part number on it. Correct part numbers for application used to be noted on Ricambi’s site and may still be. Otherwise the info is in the archives here.
    Bill
    FL
  6. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Maybe consider Fabios valved mufflers. I have his full exhaust system and it's awesome with the valves open or closed (no droning) and I'm sure he would sell you just the mufflers with the electric valve controller.
    F456M likes this.
  7. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    The way to go for sure. The drone is almost always a problem under 2500-3000 rpms. Fabio’s mufflers have the same vacuum actuator, so it is easy to put on the rubber hose to those mufflers so they will work just like befor even without buying a valve controllen. The thing with his mufflers is that they are very quiet when closed and not quiet at all when open, so the car can cruise comfortable also at higher speeds up to 100 mph, with the valves closed, but when you accellerate properly, they open and you get good sound. And they look good too with the HGTC style end tip.
  8. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    Thanks!
    These are stamped 550.
    Anyone out there want to swap for 575 or stock?
  9. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    CAPRISTO has a sale on valves mufflers
    Anyone have experience with them?
  10. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    Valved mufflers
    Spell check!
  11. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    Have valved mufflers and they work great from crazy loud to gentlemen like flick of a switch
    ralfabco likes this.
  12. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    I can’t find them. Can you help?
  13. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    I could only swap to original mufflers from the 550, I have 2 sets to them.
    Don't know if this would be an option.
    Daniel
  14. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    I think I’m going with valved mufflers.
    Any comments on Capristo or Fabio’s as a choice?
  15. Konadog06
    Aug 22, 2007
    963
    Bill
    Fabio’s look like a stock Maranello HGTC muffler. His workmanship is excellent. Should you ever choose to add the rest of his system you would already have the mufflers.
    Bill
    FL
    F456M likes this.
  16. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Il Tifoso likes this.
  17. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    Thank you very much
    F456M likes this.
  18. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
  19. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    Does anybody know if the 575 Tubi is compatible with the 456? If so, happy to swap if so.
  20. tazandjan
    39,175
    Paul- No, they are not compatible.
  21. fished43
    fished43 Rookie
    Aug 15, 2012
    18
    Dave
    Paul- My 456 has what I believe to be 1st generation Tubis. They are a little too loud for my taste. I will PM you about a possible swap.
  22. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    Thank you!
    Sounds good.
  23. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,761
    ESP
    Bas
  24. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    Fabio's mufflers arrived last Friday and today is the first chance I have had to inspect. His packaging is as good as his work! I can hardly wait to install them. I also have his "H pipe" which looks like some kind of art work.
  25. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
