too much cooling? | FerrariChat
too much cooling?
Discussion in '206/246' started by raywong, Dec 26, 2006.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    The ambient temp is about 15 deg Cels. My coolent temp needle only go up to 1/3 when I drive on the hiway. The needle goes up to 1/2 only when traffic gets heavy and slow, it will go down to 1/3 if traffic become smooth again. Is this low temp bad for my engine ? Does it sound like the thermostat is stucked open?
  2. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    It's a good place to start:)
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    Probably not stuck open, more likely the return spring is just old & weak i.e. it will open up but then won't return as fast as far as it should. It will eventually close but very slowly & after the car has cooled down completely.
    Just replace the Stat, that should solve the problem
    I.
  4. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    Also, check (or replace) the water temp sensor. My car "ran cool" until I replaced the sensor and now runs (typically) dead center.
    Hope this helps.
    Pietro
  5. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    you mean the sensor that control the fans?
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Before you start replacing parts, perhaps you could tell us if there have been any electrical issues in the history.
    Has it always run at these temps or was there a sudden change/drop recently?
    I tend to suspect the temperature sending units, gauges, and wiring connections. Please remember that these items are 1960's technology and not precision instruments.
    Happy Holidays!
  7. ENZOSON
    660
    Erie, Colorado
    PIETRO
    No the one located between spark plug 5 and 6 (towards the driver's side and the firewall). You shoud be able to replace it without draining the coolant (done when cold of course...). This gives you the temp reading and is not a switch -
    Hope this helps -
    Pietro
