Tool Kit Strap Bracket | FerrariChat
Discussion in '308/328' started by teatime, Jan 16, 2023.
  1. teatime
    teatime Rookie
    Mar 8, 2009
    43
    NW Burbs, Chicago
    Todd A.
    Hello,
    My 308 was missing the tool kit strap and bracket when I purchased it back in 2009. I finally got fed up with the tool kit being tossed back and forth in the trunk while driving, so I'm on a mission to get the tool kit secured properly. I was able to secure a strap on ebay, so I have that installed...but I now need the bracket which appears to be riveted in? I searched the threads and below is the best picture I found. Anybody know how to get this part? I can't seem to find a part number on it... maybe it needs to be custom made? Also if someone has this installed maybe you share some specs, in case I need someone to make it? Thanks in advance. (photo credit goes to user 'stonker')
  2. Rifledriver
    37,103
    30029904.
    There is a price shown but no stock at Maranello Classic. They were used up to mid production 328 and in many flat 12 cars.
  3. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    That type of bracket is called a footmans loop. Use that as your Google search term and you should get many useful hits.
  4. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    405
    PA
    Alex
    I'd check with Russ at FerrParts for a salvage one.
  5. teatime
    teatime Rookie
    Mar 8, 2009
    43
    NW Burbs, Chicago
    Todd A.
    Thank you all so very much!
  6. 4right
    4right F1 Rookie
    I have always stored mine in the front along with the spare.
  7. BigTex
    79,380
    Houston, Texas
    Bubba
    My OM depicts the small roll inside the spare, but the jack bag in the rear trunk.
  8. 4right
    4right F1 Rookie
    I knew that I saw one or the other/both in a picture somewhere with them located in the front, now that you mention it that’s probably where I saw it. Regardless, that is where I have always kept mine. Helps with weight distribution as well, lol.
  9. Sigmacars
    Sigmacars Formula 3
    1,218
    I have mine in the same place got some Belts drilled 2 1/4” holes in the fibreglass walls and used plastic push clips to hold the Belts after you cut them to length
  10. Rifledriver
    37,103
    In a later production 328 we have no choice because there was no strap in the trunk. However in a 328 both kits stow neatly down in front under the overhang and need no retention because they will not move unless you roll the car. Been doing it for decades.
    I would rather put them on the small shelf in the rear held by the strap though. It saves a lot of precious space. I actually go on trips in ours and the tool/jack kits use too much really valuable space and in the trunk without the retention strap they crash around and put dents in the rear fenders.
    I have always wished they had kept the strap but for some unknown reason it was discontinued around May 87.
  11. 4right
    4right F1 Rookie
  12. Rifledriver
    37,103
    And very shortly after that they came up with a much better idea.
