Top won't go down - 1998 355 F1 Spyder | FerrariChat
Discussion in '348/355' started by Mike Phillips, Dec 29, 2014.
  1. Mike Phillips
    Mike Phillips Rookie
    Jan 9, 2006
    7
    Stuart, Florida
    Mike Phillips
    I have a 1988 355 F1 Spyder I buffed out for a special project. Next week I want to take some beauty shots using this car and I'd really like to take the pictures with the top down.
    The owner isn't sure why it won't go down so I asked Wayne Carini who was our special guest at our Saturday Cars & Coffee show just a few weeks ago.
    Wayne checked it out and think is might be a sensor.
    Does anyone here have experience with this issue? Maybe make a suggestion as to what to look for, what to replace, etc. I'll pass this onto the owner when he picks his car up.
    Thanks ahead of time and disclaimer, I work for Autogeek but I'm not here to try to sell anything, just want to get this top down for a picture or two.
    Here's the car in question...
    Thanks,
    Mike Phillips
  2. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,022
    PA
    Kevin
    Gorgeous job on that black, Mike. I'm a big Pinnacle fan.
    Most issues with the 355 top start with a screwed up frame alignment during the retracting movement...specifically caused by worn elastic straps that assist with pulling the first "bow" not pulling back completely or evenly. I am referring to the front-most rail nearest the windshield. After unlatching the first rail from the windshield, try gently pushing this rail toward the rear of the car while nudging the second rail straight up toward the sky.
    These tops are overly complicated so more info on exactly how the top is behaving would be helpful.
  3. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    That car looks blue to me.
    Welcome, Mike. I'm a fan of your work. I can't help on this issue as I own a GTB but you've come to the right place. This is a very helpful forum and a somewhat common issue so someone knowledgable will be along shortly.
  4. WATSON
    23,857
    WI
    The list of possible issues is long.
    If you unlatch the top and push up on it slightly does it beep?
    Do the windows drop down about 1"?
    If not, then the you probably have a micro switch failure
    If it passes that test, what happens when you hit the retract button?
    Do the seats move forward? If not, it is probably the seat potentiometer. But it could be the relays on the top ECU board.
    If the seats move forward and the top starts to retract, make sure the second bar from the front flops backwards. As mentioned, the elastic straps stretch and the bar will not move backwards and gets caught in the retraction process.
    Of course, the top could need to be bled as well.
    There are several switches throughout the top, doors and seats....the ECU is always a variable.
    Fun huh? :)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,630
    San Carlos, CA
    Mitchell Le
    There is 20 reasons why the top does not go down. But, you first need to tell us what it is doing.
    1) car in neutral, parking brake engaged, windows rolled down all the way.
    2) Unlatch the top, push it back 10 inches, does it beep?
    3) If it beeps, you push the top button back, does it beep at you?
    4) If it does not beep, does it begin to move the seats forward?
    5) If the seats move forward, does the top begin to fold back, or nothing?
  6. WATSON
    23,857
    WI
    I forgot that part...but the windows need not be down.
    This top is freaking awesome! :)
    ...but once it works it's just fine.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Slight revision:
    1) Doors closed, parking brake on, ignition switch in position 2, engine not running.
    2) Unlatch the top, windows should go down about 1 or 2", push top back until you hear a beep, (about 10 inches).
    3) After the beep push and hold the top button and the seats should start to move forward. If they don't you will hear another beep indicating a problem.
    4) Once the seats stop moving forward the top should retract.
    5) Upon completion of top retraction seats should move back to original position.
    6) release top button.
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Doesn't matter if engine is running or not. Ignition just needs to be on
    Windows do not need to be lowered. Watch this video of the top being sequenced five times in a row with the engine running.
    Check out this video on YouTube:
    http://youtu.be/yw2p9ijbfV8
    Bob Ferraris
  9. johnk...
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Correct, but I was saying engine off since the car in question is an F1 and if it's running you get into all the crap about starting it.
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Before trying to operate the top again the first thing I would check is the fluid level. There is a good chance that is low or non-existent. Remove the upholstered cover between the seats and take a look.
    My top started acting sluggish this summer and bringing the fluid level up to the max line restored its vitality. Liquid viagra :)
  11. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Don't forget the emergency switch, when I bought mine it was the only way to get it down. The console switch would not work but the emergency switch would lower and raise the top.
    Before I got it fixed, thanks to Craig ;)
  12. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I was going to mention that. If it's just a switch gone bad in the system you can roll the windows down and slide the seats forward yourself then pop the little circle out of the pump cover and use the override switch. When I got mine the override was hanging out and the dealership had been using it to put the top up and down. Turns out there was nothing wrong with the top they just didn't know all the sequence of things you have to do like set the brake.
  13. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Awesome that nothing was wrong with the top, surprised they found the over ride switch lol. Mine was also hanging out from the PO, also my Indy shop guy says always complete the whole open and close cycle, all the way up and all the way down. He said the car does not like you otherwise. I have no clue what he was thinking, but I was thinking " sounds expensive " and he is the factory certified trained owns ferrari guy so ...... I listen.
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    What he is referring to is holding the switch until it beeps and all of the functions are complete. I.e. Seat movement.
    I have stopped the cycle when the top was down and noticed the seats won't move. By pushing the switch agsin and letting it finish the cycle all things function correctly.
  15. Mike Phillips
    Jan 9, 2006
    7
    Stuart, Florida
    Mike Phillips
    First....
    I'd like to say thank you everyone!
    I've been working on and running discussion forums I guess you could say professionally since 2002 when vBulletin first went commercial and it's very refreshing to join a forum, ask for help and then get really good help.
    All too often on too many forums the in-house bullies will answer with a snide remark or tell you to use the [Search] feature.
    So thank you very much for over the top stellar help with this project.
    I'm working on another project today and won't be able to try out the procedures recommended so far but I will try them tomorrow and update this thread.
  16. BucksTifoso
    BucksTifoso Karting
    Nov 24, 2013
    91
    Furlong, PA
    Randy Crownover
    What is the hydralic fluid this group is using for the top? Mine was working perfectly, but now the secondary rams? aren't finishing the job. I was going to have them change out the fluid during the next service, as I've read on here that old fliud can cause these kind of problems, but maybe I can just top it off. Hydralic fluid recommendations? Thanks!
  17. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,695
    South East
    Jimmie
    In view of your extensive experience can you explain why you regard it as bullying to think a newbie should have the courtesy to see if a solution has been previously posted ?
  18. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #18 drbob101, Jan 1, 2015
    Mercedes product. My 360 buddy bought a can and I topped mine off with it a few months ago. Made a big difference. I just added it. No bleeding , etc.
    Here it is on eBay or go to mb store
    http://m.ebay.com/itm/251380106957?_mwBanner=1
  19. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Mike,
    If you determine that something is really wrong, you may want to check a thread on making the top manual. I'm going manual later this month.
  20. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    556
    Tempe
    Jon
    Don't forget that the voltage supplying the ecu for the top must be above 10.5volts. So sometimes it does help to have the engine running to not drain the battery.
  21. WATSON
    23,857
    WI
    That's the stuff. It works fantastic. There is a full article buried here on Fchat on how to bleed the system. It is a bit complicated, but it works. I'll try & find it..
    EDIT: http://www.ferrarichat.com/forum/135464575-post5.html
    If you are to the point of making the top manual, why not just put a switch in the hole by the ashtray to operate the top with the "emergency switch"? Couple of wires & tada. Heck, you could actually use the existing top switch. Just pull the e-switch wires & connect.
    You will need to move the seats & windows manually, but you would need to do that if you went manual anyway.
    Just a thought.
  22. WATSON
    23,857
    WI
    #22 WATSON, Jan 2, 2015
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Watson
    When you make your top manual ,you dont need to move your seats forward only the back sides of the seats.
  24. WATSON
    23,857
    WI
    Makes no difference. Same travel distances. Move the seats up or tip them forward...what ever floats your boat.
  25. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    O/K
    FastVic#77 likes this.
