Torque Rating On Transfer Case Cover | FerrariChat
Discussion in '308/328' started by canadiantifosi, May 15, 2012.
  1. canadiantifosi
    canadiantifosi Formula Junior
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    Would be of help if someone could post the torque rating for the ten nuts holding the transfer case to the bellhousing.
    Have a tiny oil leak and want to check their torque in case they have loosened up over the past couple of years.
    The car is an '82 308GTSi.
    Cheers-Colin Firth
    Ontario Canada
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    They are std M8 nuts I think so around 18 lbft from memory. There is no gasket there, its usually sealed with an anearobic sealer - something like Loctite 518.
  3. Steve Magnusson
    26,806
    See Chapter M in the 308GT4 WSM (which you can download at www.ferraridatabase.com). If the stud size is M8 x 1.25P, I believe the specified value is 2.5 Kg-m (the translations aren't always clear so always good to use the thread size as a double-check).
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    The WSM does seem to specify 2.5kgm for most of the M8 x 1.25 stuff (which is 18lbft). Out on the web, a number of references to "standard" torques settings of 24/25lb ft for that size & thread. Wonder why the Ferrari spec is less than that?
  5. canadiantifosi
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    #5 canadiantifosi, May 15, 2012
  6. Steve Magnusson
    26,806
    #6 Steve Magnusson, May 15, 2012
    The torque values have to take into account the materials and the arrangement -- e.g., a steel bolt and steel nut (or a steel nut on a steel stud mounted in a steel base) will have a higher failure load than steel bolt and an aluminum nut (or a steel nut on a steel stud mounted in an aluminum base).
    In this case, the (lower) Ferrari limit is set by pulling the steel stud out of the aluminum base (not the failure of the steel threads nor steel stud). The chart posted by Matt is based on fastener load = 75% proof load of a lower grade bolt (IIRC, no markings = wimpy ;)) so those torque values are "derated" for a different reason.
  7. canadiantifosi
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    Found the leak. Looks like a pin hole in the bottom of the oil cooler where it sits above the transfer case. I started the car and gently lifted up the base of the oil cooler where it was touching the transfer case and saw drops of oil coming out. Musta vibrated a little hole where it contacted the transfer case bolt casting.
    Looks like I will be taking off the oil cooler and seeing if my rad shop can patch the leak.
    Anyone have any experience with repairing tiny leaks on 308 oil coolers?
    Colin
  8. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I was just going to ask if you'd checked the oil cooler itself :) Glad that it was an easy find.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Forget it, buy a new one. Most radiator shops will not touch that.
  10. canadiantifosi
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    Picked up another oil cooler. Had my local rad shop repair the old one so I now have a spare.
    Thanks-Colin Firth
  11. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I'm glad that it was a simple fix and that it worked out.
  12. canadiantifosi
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    Installed the new (used) oil cooler today and ran it through a couple of heat cycles and 20Km run. No drips, no leaks.
    Thanks to my buddy Veet (Vito) for picking it up for me from Roc's in Toronto.
    Cheers - Colin Firth
    Ontario Canada
  13. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,297
    Ventura, California
    Robert Garven
    Wow,
    I read this post last night and thought it could have been a hose then went to dinner and after driving the GT4 yesterday trail of oil into the garage and about a cup or two under the car looks like oil radiator is failing too. Can I ask where you found the new one? It looks like the old 016965 has been SS to 145712. Is this what you got and is it the same as I dont want to do any modifications unless necessary....
    Rob
