Torque settings | FerrariChat
Torque settings
Discussion in 'Technical Q&A' started by stevew, May 3, 2007.
  1. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    Anyone got the torque settings for the following on a 348 engine
    Crankshaft pulley bolt
    Camshaft cap nut
    Cam box nut
    thanks
    Steve
  2. fatbillybob
    Aug 10, 2002
    29,061
    socal
    I don't understand your terms I think you mean:
    off top of my head not verified:
    150ftlb crank nut 36mm
    70ftlb cam cog nut
    8 ftlbs valve cover nut
  3. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    Thanks, the crankshaft pulley bolt is one that I was after as was the valve/camshaft cover nut.
    The other one wasn't the cam pulley/cog nut, what I was after is the torque for the nuts that hold down the camshaft retaining caps.
  4. fatbillybob
    Aug 10, 2002
    29,061
    socal
    ah...try 10ft lbs but remember t wrenchs are notoriously 15% off so your most accurate in the middle of its range. 10 is likely to be at an extreme and most likely not accurate. I'd go to 10 then if it felt like I could do a bit more with the force of my palm on a ratchet head I go for it. That is not scientific but I have been at this for a long time. Otherwise get a proper t wrench
  5. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    Is 10lbft the actual factory setting or are you just suggesting that ??
    I have a proper torque wrench that has been calibrated recently, I know how to tighten nuts and bolts, I've been doing for the last 30 years :D
