You are all talking about the same bolt -- it is a 12mm bolt with a 19mm hex head (using your numbers). What model? The 308GT4 WSM has: "Nut for timing belt stretcher" "12 x 1,25" (the thread size = bolt size) "6,6 Kgm" (48 ft-lb) In the TR WSM, they improved the translation , and for the same thread size they give "5.6 daNm" (41.2 ft-lb).
In this write up for a gt4 it says 40-45 but also admitted he couldn't find the value. http://ferrarichat.com/forum/showthread.php?t=91951&highlight=belt+tensioner+bolt+torque
The 308QV/328 Workshop Manual (that you can get at Steve Jenkin's site in .pdf) gives the same (later) value as the TR WSM -- 5,6 daNm (41.2 ft-lb)
Excellent! Thank You! Steve, do you know if the cam belts are date coded? If so, do know how to decypher? See http://ferrarichat.com/forum/showthread.php?t=126966
No, I've got nothing specific on that other than a foggy recollection that the subject has come up here before.
