Torque specs for 308 calipers | FerrariChat
Discussion in 'Technical Q&A' started by pernicev, Aug 2, 2005.
  1. pernicev
    pernicev Karting
    Jun 22, 2005
    134
    The manual is a little short in this area. I'm looking for the torque specs for the brake caliper bolts, not the 19mm ones that bolt to the bracket, but the ones that are t-27 torx bolts with a nut on the inboard side and hold the outer caliper on. Also there's a small nut on the outer caliper that's covered with a plastic cap. Mine seems pretty loose. Any spec for that as well? Thanks in advance.
    Vince
